Broadband not working at regular times daily
Fixes: 334
Re: Broadband not working at regular times daily
Ah OK. Let me get my dinner and I'll get back to you - I don't user my iPads browser very often (and that is Firefox for me anyway), so I'll have to have a play.
Fixes: 334
@Ripplyuk Right, dinner eaten, washed pots, made coffee. 😀
On your Safari browser - best on the iPad - open a new tab (the '+' sign at the top R/H) and in the top box 'Search or enter website name' type 192.168.1.254 and hit enter. That should give you the login page for the router where you should fill the boxes as required - (detailed on the card supplied with the router and/or the sticker on the base of the router) under 'Router Access'.
HTH, but come back if you have more queries, I don't mind helping so long as I know how much help you need.
Ripplyuk
ETA: I think that was the wrong link. I hope this one works. There’s too much to do a screenshot. I have no idea what any of this means.
http://192.168.1.254/index.cgi?active%5fpage=9144&active%5fpage%5fstr=page%5fevent&req%5fmode=1&mimi...
Fixes: 334
Unfortunately, that won't work either. I'm sure there is a way to do a screenshot/copy page (Home & On button together) - works on my iPad anyway.
Ripplyuk
Ripplyuk
14CF3C61-4E8C-4C25-A554-C16C6A6E19B1.png33933A8F-9EAD-42C1-9A97-3AC83548881A.png65ABDCED-1513-413B-9248-F604AB3BAFEA.png
Fixes: 334
Thanks, @Ripplyuk . A quick read of that makes me think you have BT/OR network problems which need PN intervention.
Two more requests though, before I try and bump this for their attention: Do you have a landlinie phone attached to you master socket? Can you post the output from the Troubleshooter tab on the router, please?
Ripplyuk
DEEFC7CF-C8F9-4FBE-AB0E-500B8FB460F7.png7AC98656-8F9B-41A3-ACFE-1CE457519C4F.pngC26A5FA4-9D9C-4BC7-B8D4-C9554CDFEEE8.png
Ripplyuk
How do I find the output?
Yes, I have landline phone. It seems to work fine.
Fixes: 334
OK - if there is no noise on the phone, that is good.
To get the Troubleshooter page, click the 'Help Desk' tab to the left of the Event Log on the original page I posted.
Ripplyuk
My bf said there was noise on the line a couple of times but I can’t be sure if it was my phone or his and it seems ok lately.
Is this right?
Fixes: 334
Great - thanks. That kind of confirms my suspicions - initially raised by your log entry pictures.
Can you just confirm the phone is silent - Dial 17070, select option 2 - after the initial confirmation of your phone number, there should be no noise or sound other than the periodic 'Quiet Line Test' announcement.
Ripplyuk
It’s not totally silent but there’s no crackling. It’s like a hissing noise. A bit like wind.
Fixes: 334
OK - it should be totally silent, so there is a phone issue. I'll try and prod whoever of the Help team is online to have a look from their end.
Sadly , @adam945  seems to be offline now - he was on earlier, but now I've tagged him, one of the HT should pick this up next time they're around.
Ripplyuk
@jab1 Thank you for your help, John. And your patience 😁
