Broadband Speed Dropped to 10mb from 80mb Third Time
- Full Fibre
- Re: Broadband Speed Dropped to 10mb from 80mb Thir...
on 09-09-2021 9:23 PM - last edited on 09-09-2021 10:24 PM by Strat
Im on 80MB and for the third time its suddenly dropped to 10 mb last time they connected me for some bizzare reason to a different box further away so my speed just dropped right off ... Im getting sick of it. I have two mobile phone contracts land line and broadband im so frustrated I feel like throwing the towel in on all of the contracts.
Moderator's note by Dick (Strat): All caps title/text edited as per Forum rules.
Re: Broadband Speed Dropped to 10mb from 80mb Third Time
12-09-2021 4:53 PM
Hi @vince
I'm really sorry to see you're having intermittent speed issues.
Testing your line is showing an infrastructure fault on our suppliers network we'd need to arrange an engineer visit to resolve.
Can you raise a fault to us at faults.plus.net and in the notes box at the end, please tell us when you'd be free for an engineer visit. The available timeslots are weekdays (and occasionally Saturday's) 8am while 1pm, or 1pm while 6pm. This means we'll be able to arrange an engineer straight away once we've picked the fault up.
Feel free to post back once you have raised it and we'll make sure it is picked up as soon as we can.
13-09-2021 7:02 PM
Hi there thanks for your reply ...very quick I’m impressed... Anyway last night I noticed the router flashing so I knew it had started to reboot itself and when it came back on the speed was back to normal and the telephone was plugged in. So I’m not sure about the infrastructure fault if that is still there, but it seems to be working fine at the moment. My usual approach to these things is if it’s not broken don’t try and fix it . What’s your advice…….? Just see how it goes. The fault that you have identified, what detriment will it be causing now or as we move forward ...Thank you.
Vince
13-09-2021 7:20 PM
Thanks for getting back to me @VlNCE
No problem, I've tested your line again and the tests are still showing a fault so I'd recommend we arrange an engineer visit.
Some faults are fairly intermittent in nature. I've attached below a copy of the testing:
| GEA Test Detail | |||
| Circuit ID | NA | Service ID | [redacted] |
| Test Outcome | Fail | ||||
| Test Outcome Code | GTC_FTTC_SERVICE_1625 | ||||
| Description | Impairment in copper joint detected most likely in local network. Please continue to submit a trouble report. | ||||
| Main Fault Location | CE | ||||
| Sync Status | In Sync | ||||
| Downstream Speed | 73.9 Mbps | ||||
| Upstream Speed | 20.0 Mbps | ||||
| Appointment Required | Y | ||||
| Fault Report Advised | Y | ||||
| NTE Power Status | PowerOn | ||||
| Voice Line Test Result | Pass | ||||
| Radio Frequency Ingress | Not Detected | ||||
| Repetitive Electrical Impulse Noise | Not Detected | ||||
| Cross Talk | Not Detected | ||||
| Estimated Line Length In Metres | 365.6 | ||||
| Upstream Rate Assessment | Very Good | ||||
| Downstream Rate Assessment | Good | ||||
| Home Wiring Problem | Not Detected | ||||
| Downstream Policing Discard Rate | 0.0 | ||||
| Customer Traffic Level | Upstream and Downstream traffic detected | ||||
| Technology | VDSL | ||||
| Current 15Min Bin Retrains | 0 | ||||
| Last 15Min Bin Retrains | 0 | ||||
| DP Type | External | ||||
| Profile Name | 0.128M-74M Downstream, Retransmission Low - 0.128M-20M Upstream, Error Protection Off | ||||
| Time Stamp | 2021-08-31T19:30:00 | ||||
| Parameters | MIN | MAX | AVG |
| Down Stream Line Rate | 12.8 Mbps | 73.9 Mbps | 63.6 Mbps |
| Up Stream Line Rate | 0.9 Mbps | 20.0 Mbps | 18.7 Mbps |
| Up Time | 0.0 Sec | 900.0 Sec | 894.7 Sec |
| Retrains | 0.0 | 3.0 | 0.0 |
| Current and Last 15 Minute Bin Performance | ||
| Parameters | Last Traffic Count(Upto 15 mins) | Current Traffic Count(Upto 15 mins) |
| Start Time Stamp | 2021-09-13T17:55:44Z | 2021-09-13T18:10:44Z |
| Ingress Code Violation | 0 | 0 |
| Egress Code Violation | 0 | 0 |
| Errored Seconds | 0 | 0 |
| Severely Errored Seconds | 0 | 0 |
| Unavailable Seconds | 0 | 0 |
Let me know when you've raised the fault ![]()
14-09-2021 4:40 AM
14-09-2021 8:12 AM
Hiya @Shep41, thanks for your message. It does look like the line is banded yes, likely caused by the fault on the line.
If still banded once the fault is cleared, we can then send that off to be reset.
- Full Fibre
