Battery backup
shanye
Re: Battery backup
That's exactly what I needed to hear. I've learned a lot here. I assumed the signal flashing down the fibre would have needed boosting fairly often. It appears not. It's worth me preserving with this project..
ExForce9
All Star
Fixes: 11
Re: Battery backup
@shanye wrote:
I just need to find a Y cable with MFF which is actually 5.5 x 2.1mm and not anything else.
@shanye
If you search eBay for '196556788478',  isn't that what you want ?
shanye
Re: Battery backup
@ExForce9 You'd have thought so, for sure!
But no.
For some reason I can't identify, the female ends to these do not allow the male parts of my equipment to attach. It looks like the little pin inside the female is too large to fit into the hole on the male part. It's really annoying because I just can't see why none of it fits together!
mwwagain
Fixes: 4
Re: Battery backup
@bmc wrote:
@shanye
The fibre optic cable does not go to your local Exchange unless it's classed as a Main Exchange. I think they're called Internet Handover Points now (before they were  Internet Head Ends).
In the case of my rural setup, the fibre goes *past* the old copper exchange - as they had already got a fibre run to it and used the same duct to pull through that far.  Probably the same in many places as it is easy access to the local pole runs
In talking to the folks installing the CBT's, the fibre comes from a different main exchange - so is not even to the 01nnn site.
