BT Wholesale Test Error
- Full Fibre
- BT Wholesale Test Error
07-09-2021 10:43 PM
Your speed test has completed and the results are shown above, however during the test an error occurred while trying to retrieve additional details regarding your service. As a result we are unable to determine if the speed you received during the test is acceptable for your service. Please re-run the test if you require this additional information.
Been getting this since using plusnethub one.
Plusnet Hub One | Software version 4.7.5.1.83.8.263 | Last updated 10/03/19
Re: BT Wholesale Test Error
07-09-2021 11:18 PM
Then why not use another test, speedtest.net or thinkbroadband?
08-09-2021 2:20 PM
Hi @Faizan786
Do you get the same error if you try running the additional diagnostics on a different browser?
08-09-2021 4:56 PM
for ip profile.
08-09-2021 4:58 PM - edited 08-09-2021 5:04 PM
Opera and Edge, had no issues with 3rd party router for years. Recently died so went back to hub one.
08-09-2021 5:02 PM
Been on 13 day wait list for router upgrade, maybe its related to that.
https://community.plus.net/t5/My-Router/Hub-one-wifi-firmware-issue/td-p/1825681
Eventually told to ask here:
https://community.plus.net/t5/My-Router/Hub-One-5GHz-WiFi-issue/td-p/1696363/page/175
