BT Wholesale Test Error
Faizan786
Your speed test has completed and the results are shown above, however during the test an error occurred while trying to retrieve additional details regarding your service. As a result we are unable to determine if the speed you received during the test is acceptable for your service. Please re-run the test if you require this additional information.
Been getting this since using plusnethub one.
Plusnet Hub One | Software version 4.7.5.1.83.8.263 | Last updated 10/03/19
5 REPLIES 5
Mustrum
Fixes: 81
Re: BT Wholesale Test Error
Then why not use another test, speedtest.net or thinkbroadband?
Fixes: 1,662
Hi @Faizan786
Do you get the same error if you try running the additional diagnostics on a different browser?
Faizan786
for ip profile.
Faizan786
Opera and Edge, had no issues with 3rd party router for years. Recently died so went back to hub one.
Faizan786
Been on 13 day wait list for router upgrade, maybe its related to that.
https://community.plus.net/t5/My-Router/Hub-one-wifi-firmware-issue/td-p/1825681
Eventually told to ask here:
https://community.plus.net/t5/My-Router/Hub-One-5GHz-WiFi-issue/td-p/1696363/page/175
