BT Home Hubs no longer working, and half my upload speed.
pvy2712
I've been using a Smart Hub Type A for several years now, last night, around 2:30ish am, my Home Hub forgot my username and password.
No biggie, I went in and re-input them and it connected, unfortunately it was around a 4Mb/s download connection, where I had been getting 30+, while my upload was 10 Mb/s which is usual.
I have a spare Smart Hub 2 which I plugged in with similar results. I then tried the Plusnet Router and that gave me a 35 Mb/s download which is more like it, but only 6 Up which is highly confusing.
What on earth is going on?
11 REPLIES 11
Fixes: 1,491
Re: BT Home Hubs no longer working, and half my upload speed.
Moderators Note
This topic has been moved from ADSL Broadband to Fibre
Fixes: 357
@pvy2712 Don't understand why the Type A failed - age? Which Hub do you have connected now?
pvy2712
I've got the Plusnet connected now, which is fine apart from the upload speed.
The home hub "could" have failed but I doubt both of them would have.
Fixes: 357
Hub1 or Hub2? Not really a problem, but useful to know. Anyway if you can provide the detail requested below, maybe the Community can help, or PN Help Team staff will pick up.
For Community members to be able to help, information from these two sites, as screenshots:-
BT Broadband(obscuring your phone number) and BTW Performance Tester - Over a wired (ethernet) connection, please report the 'ADDITIONAL DIAGNOSTICS', and sight of the HELP DESK tab from your Hub would be a start.
wairds
About 10:00am this morning my BT Hub 6 stopped working. No internet connection. Contacted Plusnet support and they did all their tests and could not find a problem.
I then fitted a Plusnet router and it connected without a problem. Thinking it maybe a faulty BT Hub6 I set-up a spare one I had and it failed to connect to the internet as well. Stayed on the solid orange light.
I have a Plusnet engineer coming out in a couple of days.
Very strange.
RealAleMadrid
Fixes: 68
@wairds  There are no Plusnet engineers, and even if there were they would not come out to troubleshoot a 3rd party modem/router problem so who do you think is coming? If it's a Qube engineer I would cancel the visit immediately as they basically just check that that your modem/router and computer are connected up correctly, pretty basic stuff. If the Hub1 works that's it, no problem.
adam945
Fixes: 113
,Hello @pvy2712, thanks a lot for getting in touch and I'm really sorry to hear that you're having issues with your router. Uploading a screenshot of your Helpdesk page from your Plusnet Hub might help here, as a GEA test on my end is showing upload speeds of 10Mbps.
Are you still having these issues?
KBD
GEA Test Detail
Circuit ID NA Service ID
Test Outcome Pass
Main Fault Location OK
Sync Status In Sync
Downstream Speed 39.0 Mbps
Upstream Speed 10.0 Mbps
Appointment Required N
Fault Report Advised N
NTE Power Status PowerOn
Voice Line Test Result Pass
Cross Talk Not Detected
Estimated Line Length In Metres 706.8
Upstream Rate Assessment Very Good
Downstream Rate Assessment Low
Technology VDSL
DP Type External
Profile Name 0.128M-40M Downstream, Interleaving Low - 0.128M-10M Upstream, Error Protection Off
Time Stamp 2022-02-22T13:15:00
Parameters MIN MAX AVG
Down Stream Line Rate 36.1 Mbps 39.4 Mbps 36.8 Mbps
Up Stream Line Rate 9.9 Mbps 9.9 Mbps 9.9 Mbps
Up Time 597.0 Sec 900.0 Sec 899.0 Sec
Retrains 0.0 2.0 0.0
 Adam
 Plusnet Help Team - Leeds
pvy2712
Hi @adam945
Yes the plusnet router seems to be working fine now so... no Idea. not tried the other routers but as it's working...
Thank you.
wairds
I configured the Plusnet router and managed to get that working satisfactorily. Consequently cancelled the BT engineer. Spoke to Plusnet support and they have no idea as to why the BT router wouldn’t work.
adam945
Fixes: 113
Ah fair enough Smiley
I'm glad to hear that things are now working fine. Please let us know if you need any further assistance.
 Adam
adam945
Fixes: 113
Ah fair enough, thanks for letting me know, glad things are working normally now, please let us know if you're having any further issues at all.
 Adam
