Anybody on Full Fibre using a pfSense router?
JRIrish
Plusnet Full Fibre due to be installed at the end of this month. I have used my own router running pfSense for quite a while now and it works fine with a BT modem for Plusnet FTTC with IPv4 Configuration set to PPPoE.
Would I be right in thinking I don't have to change anything for Full Fibre?
Same username and password?
And leave the IPv4 set to PPPoE?
In other words simply plug a Cat6 cable into the new modem and other end into the pfSense router and Bob is your uncle while Fanny is your aunt?
Jerry
2 REPLIES 2
Fixes: 569
Re: Anybody on Full Fibre using a pfSense router?
In a word, yes!
Open reach will fit an ONT which is effectively the modem, just plug the cat6 into that.
JRIrish
Thanks for that. Unfortunately my order has been delayed for some reason but I will get Full Fibre at some point. Good to know that I don't have to do any configuration changes for when it does arrive.
Jerry
