Additional router
Martin01
Additional router
Could anyone post some details on how to add my old plusnet hub1 to my new hub2 router as a wireless access point , we don’t get a good WiFi signal upstairs so want to connect hub1 to hub2 via a network cable
Thanks in advance
3 REPLIES 3
Fixes: 579
Re: Additional router
@Martin01
https://community.plus.net/t5/My-Router/Using-a-2nd-Plusnet-Hub1-as-a-Wireless-Access-point/td-p/138...
Fixes: 147
@Martin01
With the Hub One working as a wireless access point will result in the 'b' (broadband) light to flash due to the Hub One seeing no DSL connection. This can not be turned off.
You could cover the light with dark tape or I have found it is possible to peel off the small plastic cover where the light is and cover the led with dark tape, replace the cover. Looks a bit better.
HTH
Dan.
Mav
Fixes: 518
Moderator's note(s):
Two unhelpful posts removed.
Forum Moderator and Customer
