Activation date
waltersn2001
Activation date
Hello,
My activation date was supposed to be today but had an email form plusnet stating that my new activation date is now the 2nd January. Why would this be as I already have full fibre at the house, and I'm taking over as a new customer. So I'm going from Plusnet to Plusnet but faster broadband. Can anyway clarify? Thanks
9 REPLIES 9
Longliner
All Star
Fixes: 8
Re: Activation date
Well, today is a public holiday with even our shops are closed ... still, you should not have been booked for a New Year's Eve call when OR will be trying to fix emergency faults. Will 48 hours make that much difference?
Happy New Year to everyone!
Mike
waltersn2001
Re: Activation date
Well it wasn't activation was meant to be yesterday which is was the 31st which is a normal working day, besides I read that for each day they go over the date you should get compensation for
Fixes: 585
Re: Activation date
@waltersn2001
was yesterday a 'confirmed' date or was it 'we expect to install...' ?
waltersn2001
Re: Activation date
Well it said expected activation 31st December, don't understand what you mean? The date you're given is surely the date it should be.
Fixes: 585
Re: Activation date
Ah! well no, this is Openreach/BTwholesale we're talking about !!
When you place an order with an ISP, the system gives the earliest possible 'estimated' date. Once Openreach/BTw have accepted the order they provide a 'confirmed' date which may/or not be later than the initial estimate.
Sound like in your case, the initial estimated date was yesterday, and once accepted , Openreach confirmed the actual date as tomorrow and Plusnet relayed that confirmation to you.
Since its a Full fibre install and you say the property already has it, it SHOULD just be a remote activation. Make sure the ONT is left powered as Openreach will try and test the connection as part of the ordering process. If it fails, then the order will revert to an engineer install which will delay it for some days.
Do you already have the Plusnet router ?
waltersn2001
Re: Activation date
Thanks for that information, I didn't know this I just assumed the date given was the date I thought it would be. Yes I already have a Plusnet router and I have fibre anyway so I thought it would of been straight forward. I haven't plugged the new router in yet as I was advised not to.
Fixes: 480
Re: Activation date
@waltersn2001
The Router is irrelevant at this juncture. If the ONT was powered off at the time that Openreach tested the connection then remote activation is unlikely to be attempted.
waltersn2001
Re: Activation date
The ONT is always on I don't touch any of that so don't quite understand what the problem would of been, I'm taking over the line as a new customer with Plusnet as I'm moving in with my partner and he already has Plusnet fibre which ends tomorrow
Ritu_D
Re: Activation date
Hi @waltersn2001
Welcome to the community.
I appreciate this has been confusing due to the expected activation date.
With today being your activation date, let me know if you experience any issues after today.
Ritu
