80/20 FTTC Trial Closed
- Full Fibre
- 80/20 FTTC Trial Closed
Re: 80/20 FTTC Trial Open
11-06-2012 3:56 PM
Quote from: marcyd As I was on 37.5 - 8.1 before the trial so would have expected 65/70 ish
It doesn't work like that. On a 40/10 product you will get the maximum possible speed up to a certain distance from the cabinet (all other things being equal). On 80/20 you will get the maximum possible speed up to a shorter distance. At any particular distance, your speeds on either product will be the same, subject to the caps that are imposed by the product, 40/10 or 80/20. If you are near the distance limit for maximum speed on 40/10, you will see little or no improvement from 80/20.
11-06-2012 9:34 PM
Anybody got any idea's, been like this all week
Profile is allso down as its showing 20mb
12-06-2012 9:55 AM
12-06-2012 10:00 AM
Quote from: Mocca Profile is also down as its showing 20mb
Do you mean the BT IP Profile or the Plusnet "line speed"? If the latter then it should be 20Mb for everyone. Anyway, with speeds like that you should raise a fault if you haven't already.
12-06-2012 11:24 AM
Quote I've been waiting the last few weeks and can't decide whether to jump on to the trials?
Get on board! we don't have a fixed date for the end of the trial. At the end of the trial, unless you've asked to stay on an 80/20 product we'd change the connection back to it's previous state, i.e 40/2 40/10 FTTC depending on which of those services you had before.
12-06-2012 11:49 AM
And yes it was teh plusnet Profile that showed 20, strange allso as last time i looked about 3 weeks ago it was 70.
12-06-2012 12:05 PM
Did you try disconnecting/reconnecting the router when the speeds were low? Odd it should fall so low for a significant time then return to 'normal'. Possibly related to some of the recent maintenance? What's your current connection time on the router?
12-06-2012 2:04 PM
My connection should be being set to 80/20 at some point today. I bought an HG612 (I like to have a spare modem knocking about) via Ebay that arrived last night which I promptly unlocked. However, I wasn't sure what VPI/VCI, annex, plan, etc. to configure on it. i've done some googling but couldn't find anything conclusive so could someone kindly list the important options I need to set. I'll be connecting the modem to the Netgear router that Plusnet sent me initially and eventually I'll connected it to either an Ubuntu 12.04 or a pfSense VM and let the VM make the PPPoE connection. From memory (I'm at work at the moment) the options I need to set are:
- VPI/VCI (should this be 1/32?)
- Mode (Bridged_IP?)
- Annex (B?)
- VLAN (101?)
There are probably some other settings that I've forgotten.
Once I've got the unlocked modem working I'll try and get those scripts running to pull some connection stats out of the modem and build some of those nice graphs.
Thanks,
Steve.
12-06-2012 2:31 PM
16-06-2012 3:26 PM
BT ADSL checker says "Our test also indicates that your line currently supports a fibre technology with an estimated WBC FTTC Broadband where consumers have received downstream line speed of 54.4Mbps and upstream line speed of 15.7Mbps."
BT speed test results are :
Download speedachieved during the test was - 46.29 Mbps
For your connection, the acceptable range of speedsis 12 Mbps-54.1 Mbps .
Additional Information:
IP Profile for your line is - 54.1 Mbps
Upload speed achieved during the test was - 8.43Mbps
I would have expected the upload to be a bit higher, possibly about 12 or 13 ? I occasionally reboot the router but the modem has never been been off since fibre was installed on 24 February. Would a modem reboot make any difference or is around 8 the best upload speed I can expect ?
16-06-2012 3:51 PM
16-06-2012 4:40 PM
18-06-2012 2:47 PM
waited over 5 hours for an engineer to come on saturday as per the appointment, he never showed up, so reported that back to PN and was told i'd get a call 1st thing in morning to rearrange, still waiting for that call,
my speeds are still getting lower dl well below 20 but up is round 6.5
18-06-2012 4:05 PM
I've just placed an order that should hopefully remedy that tomorrow. Please let me know if not.
@momsieden
FYI we'll be in touch as soon as another appointment has been arranged. Sorry for any inconvenience.
18-06-2012 4:42 PM
