80/20 FTTC Trial Closed
- Full Fibre
- 80/20 FTTC Trial Closed
Re: 80/20 FTTC Trial Open
26-03-2012 9:36 PM
Can someone please explain to me why at 7:30 in the morning it's 75Mb but at 9:30 in the evening it's 2.5Mb.
Gerry.
26-03-2012 10:05 PM
Quote from: Gerry And again we are back to abyssmal speeds.
Gerry.
I hear you, although I'm also not getting anywhere near the speeds I think I should be getting in the mornings
My ticket is ongoing, but this evening was particularly bad, nearly unusable.
26-03-2012 10:25 PM
Don't get me wrong, I know it's a trial, but if they are tinkering with things, I wish they'd let us know. I really don't want to be doing this every night, but if I have to then please tell me.
Here's hoping it stays put for now.
Gerry.
27-03-2012 12:07 AM
Had planned to watch Mad Men on the AppleTV so went to download it and it said it was going to take between 3 - 8 hours before I could start to watch it !
Left it about 45 minutes and hardly any was downloaded.
Speed test with the BT requested one get a maximum of 20mbps but I really seeing a lot worse than that - - less than 5mbps.
Rebooted modem and not much better.
Watched a movie I had recorded on the PVR instead.
So much for "super fast Speeds day or night" etc. etc.
27-03-2012 9:25 AM
27-03-2012 9:34 AM
I then ran test3 as directed and it failed both times
I have updates my ticket #53237078
27-03-2012 11:07 AM
Quote from: ffox What do you think of the packet loss I'm getting in the evening?
Had something similar (worse, if anything) last night, dropped and reconnected PPP session to change gateways and the dropped packets seemed to stop:
The two large red spikes arouind 11:30PM & 12AM was me reconnecting (first attempt still gave very poor speedtest).
A speedtest at the time of the packet loss was really bad (about 5Mb down), after reconnecting it was pretty much back to my normal 55Mb.
Pings (to bbc.co.uk) before and after were about my 'normal' 14ms (my FTTC is interleaved, previously it managed as low as 8ms).
27-03-2012 12:08 PM
Quote from: Gareth6 I'm not sure if this is related but my connection died at 12pm dead last night, hasn't connected since (i light is amber). Tried with the modem plugged into the pc directly and the CHAP authentication kept failing. There is a ticket open, just following the directions of the voicemail 'turn the router off for 65mins! Then phone back'.
Hi Gareth(6) This sounds very similar to what happened to me. Went down at 00:04 ish last Wednesday and hasn't been back since (bar 4 hrs on Saturday when the BT engineer was here) - It was a fault (originally) with what happened when they changed my profile to the 80/20.
I also get 'authentication failed' when I connect to the modem directly. I'm sitting here staqring at the orange light on the router wondering if it'll ever be blue again.... It'll be a week tomorrow and frankly my patience has pretty much run out. It's lucky for <provider> that I have an alternate method (albeit an expensive method) of getting some form of internet.
Hopefully you'll have better luck!
27-03-2012 12:49 PM
Broadband
Posted on: Tuesday 27 March 2012, 12:08
Since Sunday afternoon we have seen an unusual increase in the number of broadband customers reporting slower than expected speeds and performance problems during the evening. This is particularly noticeable by customers using our Fibre services.
Further investigation suggests that those experiencing problems are being routed via a particular site that we use for broadband provision (Faraday).
We have been in contact with our suppliers who have acknowledged the existence of a problem and assigned us a case reference.
If you think you are affected by this problem then you may be able to restore normal service by disconnecting and reconnecting. Whilst it's not guaranteed, this may result in your traffic being routed via an alternative site that is not subject to these speed issues.
We are awaiting further updates from our supplier and will post further details as soon as we have them.
Apologies for the inconvenience.
Kind regards,
Customer Support
27-03-2012 12:50 PM
Just closed my ticket now that they know about it.
27-03-2012 12:52 PM
Further investigation suggests that those experiencing problems are being routed via a particular site that we use for broadband provision (Faraday)."
Following this Status Update, I've disconnected/reconnected, so let's await what happens to download speed this evening. Indications are positive though: even my Vista PC just reported over 75Mbps
27-03-2012 1:46 PM
Quote from: Spesh
Still down a week later? Damn
That does sound very, very similar to what I'm experiencing. I did mention this trial in the support ticket. Have you tried reverting to the old profile?
I did have a similar issue with ppp/chaps a few weeks ago with my old ADSL provider, plusnet is checking if any work took place in my exchange last night.
Openreach is starting to look allot like the trains/ railtrack, really expensive to run (compared to elsewhere in Europe) and doesn't work all that well.
27-03-2012 1:47 PM
27-03-2012 2:43 PM
<snip>
Is Faraday associated with particular gateways? I was wondering if using the gateway checker would enable people to determine if they had managed to hit an alternative?
27-03-2012 2:59 PM
Quote from: Timalay This may have been asked already on here, so if it has I apologise. But when Plusnet move to offering 80Mbps/20Mbps speeds (as a service and not a trial). Will just be a simple upgrade from 40Mbps or will plusnet offer them as two separate packages?
There will be an additional cost for the 80/20 service, so I'm sure they will be separate packages, probably with the option to switch between them on a monthly basis.
