WBC FTTP availability
- Full Fibre
- WBC FTTP availability
21-07-2016 1:11 PM
Hi all,
For WBC FTTP to be available to me I realise I check on BT Wholesale checker but is this an exchange and / or line upgrade?
And also is it a plan to enable all exchanges like this or only a select number?
Many thanks
Steve
Re: WBC FTTP availability
21-07-2016 1:15 PM
It is an exchange and infrasctructure upgrade, as it's a new Fibre connection it would be an upgrade to exchange equipment and new equipment externally.
As far as roll out plans go only BT know this but a country wide rollout would be good, with other technologies such as g.fast though I doubt FTTP will be rolled out everywhere.
21-07-2016 1:42 PM
If BT Openreach isn't currently installing WBC FTTP in your area, then the best place to find out what is happening in your local area is the BDUK.
There are separate bodies for English council areas, Digital Scotland , Superfast Cymru and Northern Ireland Broadband Improvement Project so you will need to google which one is appropriate for you.
21-07-2016 2:12 PM
I'll have to ask the team upstairs responsible for the BDUK rollout in East Sussex, luckily I work in the same building!
