Squeezebox audio streaming
- Full Fibre
- Squeezebox audio streaming
01-01-2011 3:37 PM
I wonder whether any of those taking part in the FTTC trial have a Logitech Squeezebox. There are reports on the Squeezebox forum of problems connecting to the BT Home Hub Infinity router using WPA encryption. Has anyone experience of this? What other routers might be considered? I don't want to upgrade to FTTC only for my Squeezebox to cease functioning.
Message 1 of 3
(1,941 Views)
2 REPLIES 2
Re: Squeezebox audio streaming
01-01-2011 10:51 PM
For the trial you won't get the BT home hub router. I just got a BT modem supplied by BT and a separate Netgear N150 router from Plusnet.
Message 2 of 3
(517 Views)
03-01-2011 6:24 PM
Thanks for that.
Message 3 of 3
(517 Views)
