FTTP (trial) recent connection drops (Bradwell Abbey)
JakTheBiscuit
After a long period of stabillity (> 1 year I think), in July 2015 have had 4 recent connection drops (Bradwell Abbey).
The last one was about 25 mins ago and have just reconnected so posting this straight away.
Powering off the BT Openreach modem for 20 mins seems to solve them mostly.
On the hottest day of the year, experienced a red LED on the BT modem at the LOS position, and this connection drop lasted several hours.
I was concerned that when I got through to Plusnet customer services (online chat) they told me they would not raise a ticket for me as they do not consider trials as part of normal service!  Someone at Plusnet please confirm that this is not the case!?  Angry Embarrassed Shocked
9 REPLIES 9
MattyC
Fixes: 46
Re: FTTP (trial) recent connection drops (Bradwell Abbey)
Yeah that's not right, apologies. I'll give them a telling off on your behalf.
<img src="http://community.plus.net/visualradius/generated/image14367772928110.png"/>
I see a few cut outs here. However, a bit of consistency other than yesterday afternoon. Are you ok to keep monitoring for now, and if these cut outs increase, are you ok to let me know?
Matty
JakTheBiscuit
Thanks, and yes I'll let you know if further cut-outs occur.
JakTheBiscuit
Quote from: MattyC
Just had another connection drop, starting around 1648 hrs today, with a red LED on the BT modem at the LOS position.
JakTheBiscuit
Quote from: MattyC
Currently having a connection drop, started around 1903 hrs today, with a red LED on the BT modem at the LOS position.
JakTheBiscuit
Had another connection drop last night, starting around 2210 hrs, with a red LED on the BT modem at the LOS position.
JakTheBiscuit
Had another connection drop today starting around 1019 hrs, with a red LED on the BT modem at the LOS position.
This is still a problem now, even after powering off the BT openreach modem for 20 mins.
JakTheBiscuit
Connection now back up, after powering off the BT modem for 40 mins.
PeterPan
I don't want to appear smug (honestly), but I am also on "the Plusnet FTTP Trial" on Bradwell Abbey and have not noticed any problems.  In fact, I have had only one outage in almost 5 years.
I don't suppose this helps you very much, but it does show that it is not the whole of Bradwell Abbey.
Good luck.
Peter
JakTheBiscuit
Hi Peter,
Yes I had had a stable connection for a long time prior to July 2015, too.  I am guessing my connection is through a card at the local exchange which has developed a fault - possibly a tendency to overheat.
