new gea test please
FIXED- Subscribe to RSS Feed
- new gea test please
Re: new gea test please
09-08-2018 10:46 PM
yep dlm has kicked in on your line mate thats what it did on my line can tell by the upload im going to leave well alone now no doubt your pings are higher to that is another way to see it puts your line on interleaved and not fast path
09-08-2018 10:46 PM
I did try on Billion 8800NL, TP Link Router and Plusnet Hub One Router, all same result, my fibre now giving up 79999K Sync Rate. Been like this for 4 years since 2014 until last few days ago - 79.9Mb bang gone down to 77.7Mb
09-08-2018 10:51 PM - edited 09-08-2018 10:51 PM
I think DLM does kick in because I believed my cabinet could be in crosstalk now (cabinet fill up) Maybe Gandalf PN Staff will find out for me of why it drop?
10-08-2018 11:45 AM - edited 10-08-2018 11:47 AM
@iangilf Very strange and odd. I just swap over to my old fibre router Netgear DGND3700v1 and try this and it get higher sync rate with BT IP Profile of 76.27Mbps. Three router stats below:
Before on Billion 8800NL Router:
Downstream Upstream
Line attenuation (dB): 11.9 0.0
Signal attenuation (dB): Not available on VDSL2
Attenuation rate (kbps): 79920 27465
Connection speed (kbps): 77788 19999
SNR margin (dB): 6.5 15.1
Power (dBm): 12.4 0.9
Interleave depth: 8 1
INP: 49.00 0
G.INP: Enabled Not Enabled
Before on Plusnet Hub One Router:
Downstream Upstream
Line attenuation (dB): 11.2 13.1
Signal attenuation (dB): 11.2 13.0
Attenuation rate (kbps): 78264 26077
Connection speed (kbps): 77735 19999
SNR margin (dB): 6.1 15.0
Power (dBm): 12.4 1.0
INP: 49.00 0
G.INP: Not Enabled Not Enabled
Now running on Netgear DGND3700v1 Router:
Downstream Upstream
Line attenuation (dB): 11.1 12.8
Signal attenuation (dB): 11.1 12.7
Attenuation rate (kbps): 78148 26443
Connection speed (kbps): 78882 19999
SNR margin (dB): 6.1 15.1
Power (dBm): 12.5 0.6
INP: 38.00 0
10-08-2018 12:23 PM
@goldenfibre It looks like you're currently in sync at 78.8Mbps looking at a GEA test.
The connection isn't banded though and still shows a profile of 0.128M-80M Downstream, Retransmission Low - 0.128M-20M Upstream, Error Protection Off
It looks like there were a few drops back on the 4th and the sync rate dropped at this time.
There was another drop on the 6th, but since then it seems to be stable and the MTBE errors has gone back up to almost what it was prior to these drops. While I can't give an exact cause for this, I imagine the sync drop is related to the few connection drops on the 4th.
10-08-2018 12:28 PM - edited 10-08-2018 12:30 PM
@HarryB could I have GEA Test result & connection logs please. Thanks
10-08-2018 1:59 PM
GEA Test Detail | |||
Circuit ID | NA | Service ID | [Removed] |
Test Outcome | Pass | ||||
Test Outcome Code | GTC_FTTC_SERVICE_0000 | ||||
Description | GEA service test completed and no fault found . | ||||
Main Fault Location | OK | ||||
Sync Status | In Sync | ||||
Downstream Speed | 78.8 Mbps | ||||
Upstream Speed | 20.0 Mbps | ||||
Appointment Required | N | ||||
Fault Report Advised | N | ||||
NTE Power Status | PowerOn | ||||
Voice Line Test Result | Pass | ||||
Bridge Tap | Not Detected | ||||
Radio Frequency Ingress | Not Detected | ||||
Repetitive Electrical Impulse Noise | Not Detected | ||||
Cross Talk | Not Detected | ||||
Estimated Line Length In Metres | 243.6 | ||||
Upstream Rate Assessment | Very Good | ||||
Downstream Rate Assessment | Very Good | ||||
Interference Pattern | Not Detected | ||||
Service Impact | No Impact Observed | ||||
Home Wiring Problem | Not Detected | ||||
Downstream Policing Discard Rate | 0.0 | ||||
Customer Traffic Level | Upstream and Downstream Traffic Detected | ||||
Technology | VDSL | ||||
Profile Name | 0.128M-80M Downstream, Retransmission Low - 0.128M-20M Upstream, Error Protection Off |
10-08-2018 2:17 PM - edited 10-08-2018 2:18 PM
10-08-2018 2:32 PM
10-08-2018 4:03 PM
@goldenfibre's change in speed is not the DLM's doing! The DLM has not lowered the speed due to crosstalk. It does not work like that. The increased crosstalk has lowered the speed.
10-08-2018 5:36 PM
rubbish crosstalk dont change paths to interleaved latency dlm does
10-08-2018 5:38 PM
people dwell on crosstalk now as everthing but it isnt the cabs are more than capable of sustaining maximum sync rates bt engineer proved that with my faults its the copper pair thinning out or degrading they swapped me on to a different pair and still the same cab and port and my stats have shot up so dont dwell or use crosstalk always as the fault
10-08-2018 5:49 PM
I wasn't aware @goldenfibre's line ever changed to using interleaving rather than retransmission.
10-08-2018 5:49 PM
im over 140 meters away by the estimated line length of golden fibres and i get full sync now cause ive been put on a better quality pair has nothing to do with crosstalk its about the quality of pair and about dlm not interfeering not crosstalk as i went threw the same as what golden fibre is going threw and its definately a cable pair issue with dlm and definately not crosstalk
GEA Test Detail
Circuit ID | NA | Service ID | BBEU22614246 |
Downstream Speed | 80.0 Mbps | ||||
Estimated Line Length In Metres | 386.8 | ||||
Downstream Rate Assessment | Reasonable | ||||
Profile Name | 0.128M-80M Downstream, Error Protection Off - 0.128M-20M Upstream, Error Protection Off | ||||
Time Stamp |
2018-08-08T12:15:00
10-08-2018 5:52 PM
also my stats now are
Upstream | Downstream | |
Current Rate (kbps) | 20000 | 79987 |
Max Rate (kbps) | 31790 | 86303 |
SNR Margin (dB) | 12.7 | 7.5 |
Line Attenuation (dB) | 18.6 | 9.5 |
Errors (pkts) | 110 | 4 |
as i swapped modem router and im not even syncing at full speed now so it can depend on routers aswell
