WiFi strength from the Plusnet Router
ian2richardson
We have just oved from BT and find that the in-house WiFi signal strength is poor.  Is this a factor of the PlusNet router?
12 REPLIES 12
Method0ne
Re: WiFi strength from the Plusnet Router
In a word, yes.
In several, the wifi isn't especially good on the supplied router due to it being a budget unit that works for the majority of smaller modern households, and the fact that it doesn't have an external antenna doesn't help that.
Jaggies
@ ian2richardson
You can always use your Home Hub.
See here.
uther
You could also try changing the wireless channel from automatic to manual. My wifi was showing 0.50mbps on speedtest with automatic, now its 25mbps on channel 6...
chenks76
All Star
Fixes: 12
depends what you mean by "poor".
i can still connect to WIFI from outside the front of my house and the router is at the back of the house on the top floor.
wifi on the pn router may not be the best (just about every ISP claims their router has the best wifi range - they can't all be), but it's certainly not the worst.
the sky sr101 router had piss poor wifi range when i used it - and that just internal coverage.
adamwalker
Fixes: 221
A good way to get the most out of your WiFi router (assuming you're a Windows user) is to use the following command prompt:
netsh wlan show networks bssid
This will show you all the local networks picked up by your PC's WiFi adapter. It shows you which channel they're using so you can make a better judgement as to which to avoid when changing yours.
 Adam Walker
uther
WiFiInfoView also works very well for this. I originally changed to channel 6, then after running that found a few local networks on 6 and changed to channel 13. Gained quite a bit by doing that.
CTFU75
The better alternative is Powerline Adapters like Devolo Netgear  which prevent you being exposed to the wifi emf issue.
Thats if you believe this issue is a health risk. The French seem to think there is an issue for kids and have banned their use in schools so if you have young kids it may be worth getting one to prevent exposure.
The DECT wireless phones are a lot worse too even more than a mobile I believe as the base station is 24/7 exposure. Base could be by your bed while you sleep pumping out at you. Although there is one brand where the base  doesn't emit out until you actually pick up the phone so exposure back down to mobile phone exposure times.
PeterLoftus
Fixes: 5
Or you could make yourself a hat out of aluminium foil  Crazy
To do is to be - Neitzsche
To be is to do - Kant
do be do be do - Sinatra
CTFU75
Professor Lawrie Challis from the University of Nottingham, an expert used by the government to evaluate risk from EMR, says radiation exposure from a mast was at most 1/1000th that from mobile phones.
If you've got twenty minutes PeterLoftushttps://www.patrickholford.com/advice/are-you-being-electrified
PeterLoftus
Fixes: 5
@carb I think we should both butt out and let the OP get his issue dealt with Smiley
CTFU75
I agree with chenks76. The router has been independently tested by Which? it was given excellent wireless yet the ethernet ports only offer slower data transfer speeds of 100Mbps rather than 1,000 Mbps that some rivals provide. Yes they also found that it doesn't intelligently choose which wi-fi channel to use for beaming out its signal. It had a better score than the BT HH also.
HairyMcbiker
All Star
Fixes: 21
Myself and many others have complained about this in the past. The best bet is to use your previous BT router if it is a HH3/4/5 then you are good to go, with the 3/4 connect to the modem and RESET your hh to defaults. Then setup using your <user>@plusdsl.net & password.
For the 5 reset as well, plug direct into the cable coming from the telephone socket removing the BT white modem, and setup as above.
You need to do a reset as you no longer have access to FON and don't want it on your wifi.
