WiFi Passwords
- Re: WiFi Passwords
WiFi Passwords
15-11-2021 6:51 PM
Hello.
Do i have to use different passwords for the 2.4 Ghz band and the 5 Ghz band ????. can anyone advise me please.
Re: WiFi Passwords
15-11-2021 6:52 PM
No - use the same password for both.
Re: WiFi Passwords
15-11-2021 7:07 PM
Hello.
When i try using the same password on the 5 Ghz band nothing will connect, laptop, mobile phones, firestick. They will only connect to the 2.4 Ghz band.
Re: WiFi Passwords
15-11-2021 7:08 PM
Are any of those items 5Ghz capable?
Re: WiFi Passwords
15-11-2021 7:18 PM
Hello.
Yes they are all 5 Ghz capable.
Re: WiFi Passwords
15-11-2021 7:20 PM
Very strange, because the advice I gave is the standard one - from people with more experience in these matters than me. Have they connected to 5Ghz previously?
Re: WiFi Passwords
15-11-2021 7:39 PM
Yes they have, but today i have had a lot of problems with my line connection, had to do several resets of my WiFi connection on the hub and the Plusnet techies are monitoring my line overnight. They have raised a ticket on my line problems, just have to wait and see what it is like tomorrow.
Re: WiFi Passwords
15-11-2021 7:41 PM
OK, but note my comment re the password. It helps, BTW, if you give all relevant information when you raise a query.
Re: WiFi Passwords
16-11-2021 10:00 AM
Hi @OldFrank
I'm sorry to see you can't connect to the 5GHz wireless band.
Could you find out what firmware your router's on? If you go to your router's settings at http://192.168.1.254 and at the bottom you'll see the 'software version'. Let me know what this says as I suspect you may not be on our latest version.
Re: WiFi Passwords
16-11-2021 10:22 AM
Hello.
I am on the latest version firmware: 4.7.5.1.83.8.263.
The problem seems to be that the 2.4ghz overrides the 5ghz on all of my devices. my devices can see the 5ghz band but cant connect to it, which is a shame because I am on the 80mbs fibre. The only way to connect to the 5ghz is to disable the 2.4ghz which seems a bit senseless.
Re: WiFi Passwords
16-11-2021 10:25 AM
Re: WiFi Passwords
16-11-2021 10:30 AM
Thanks for the info about the firmware.
Re: WiFi Passwords
16-11-2021 10:48 AM
Hello.
My firmware version is: 4.7.5.1.83.8.263
many thanks
Re: WiFi Passwords
16-11-2021 1:41 PM - edited 16-11-2021 1:43 PM
Re: WiFi Passwords
16-11-2021 1:51 PM
Will that be the same firmware that @bobpullen is pushing out ?? and how long will i have to wait ?
Cheers.
