Where to start
- Where to start
Re: Where to start
02-06-2018 2:33 PM
Hi @WhatsWrongNow, from what you've said the problems you're experiencing do appear to point towards a wireless issue, which I'm afraid is unfortunately out of our control.
Having said this, it may be worth de-syncing the 2.4Ghz and 5Ghz connection frequencies on your router by changing the SSID for one of them so your devices doesn't automatically try switching between these.
This post can help with instruction on doing this: https://community.plus.net/t5/My-Router/Devices-stop-working-on-5-GHz-connection-Wifi-drops/m-p/1395...
I hope this helps.
Re: Where to start
02-06-2018 2:39 PM
I understand WiFi outside of your control but there must be knowledge out there. At least in the first instance to tell me what’s normal and what’s not eg screenshots
Re: Where to start
05-06-2018 5:16 PM
@WhatsWrongNow wrote:
Thanks but again see previous post 5ghz is disabled
Apologies I missed that when I made my previous response.
Some pointers for getting the most out of wifi can be found over here: https://www.plus.net/help/broadband/getting-the-best-wifi-signal/
I hope this helps.
Re: Where to start
05-06-2018 6:51 PM
For now is the orange WiFi light on the hub an error or present light
Re: Where to start
05-06-2018 7:27 PM
Re: Where to start
05-06-2018 7:29 PM
Re: Where to start
05-06-2018 7:55 PM
Hi @WhatsWrongNow,
Thank you for confirming that. In that case, I would recommend that you try a factory reset of your router. There's a pinhole on the back and you'd need to push something into this for at least 15 seconds whilst the router is powered on. Please be aware that this will remove any custom settings/passwords that you may have set up on the router.
Please let us know how it goes.
Re: Where to start
05-06-2018 8:05 PM
I had a new router because of the same fault and I was with BT before that and had the same faults
I appreciate that you didn’t know this but now you do hopefully you will agree that this is hiding the symptoms not getting to the fault
There must be some kind of diagnostics or tests you can run while it’s in this status
Re: Where to start
06-06-2018 8:20 AM
Re: Where to start
06-06-2018 11:52 AM
Hi @WhatIsWrongNow,
Thanks for providing us this information. Based off of what you've said so far and everything else in this thread, it's likely that there is something in the area that's causing interference with your Wireless Signal which would explain why this issue seems to happen despite having changed ISP's and Routers.
I've tested your line today and everything appears to be working fine from our side which is more evidence to support this theory, so at this stage it's worth trying to figure out whether or not the interference is being caused by something within your own control, like another device within your property.
Re: Where to start
06-06-2018 12:06 PM - edited 06-06-2018 12:08 PM
In the meantime can you tell me why the WiFi thinks it’s down but it’s working? What are the constant invalid illegal and wrong order packets being received and what’s the perceived TCP reset threat? Currently Fing is showing my hub with the local address of .67 as well as where you would expect it. I’ve been told previously that two routers can be seen on the line can you check?
Re: Where to start
06-06-2018 1:05 PM
I've checked the line today and can't see any history of two routers being connected to the line at once and it's hard to say what's causing the the issue you're having with the WiFi light as it's certainly not something that I have seen before. Have you been able to perform the factory reset as suggested by my colleague, Emily, yet?
Re: Where to start
06-06-2018 1:12 PM
Re: Where to start
06-06-2018 1:23 PM
Re: Where to start
06-06-2018 1:47 PM
Would you do me a favour and answer previous questions too
