What type of DSL line is used between the FTTC cabinet to modem?
- Re: What type of DSL line is used between the FTTC...
11-08-2016 9:05 PM
I'm having a spot of trouble with my router (a Fritz!Box 7390), and the manufacturer has asked me this:
> What kind of DSL line (for example DSL 16000) are you using your FRITZ!Box?
I know it's VDSL, but is there a more technical term for the line?
Message 1 of 2
(595 Views)
1 REPLY 1
Re: What type of DSL line is used between the FTTC cabinet to modem?
11-08-2016 11:46 PM
Its a strange question, but you can tell them ... they should know to be honest, in the UK, we are using 'VDSL2 Profile 17a'.
3Mb FTTC
3Mb FTTC
Message 2 of 2
(567 Views)
