Was it worth it?
- Was it worth it?
Was it worth it?
04-09-2015 9:21 AM
Ok...................................moved from Sky cos' my speeds for super fibre were poor. Guess What No change!!
Postcode: Phone exchange :RHOSLLANERCHRUGOG Estimated line speed:35Mb (Download speed could vary depending on line conditions. Estimates are the maximum speeds that your phone line can support. These speeds are dependent on the package you choose.) - Checked on 2015-07-27 16:21:31Current line speed:21 Mb
Estimated line speed: 6Mbps
Current line speed: 21Mbps
This is the e-mail I get today and I think why?? Do I put some sort of fault report in? Those figures are really poor
Message 1 of 7
(957 Views)
6 REPLIES 6
Re: Was it worth it?
04-09-2015 9:24 AM
Can you post the results from http://www.dslchecker.bt.com/adsl/adslchecker.welcome please
Message 2 of 7
(656 Views)
04-09-2015 1:49 PM
Your currently syncing at around 28mbps which is 7mbps below your estimate.
It may be worth raising a fault to see what we can do although I can't promise the speeds will get better.
You can raise a fault here https://faults.plus.net
Message 3 of 7
(656 Views)
04-09-2015 1:52 PM
Why do people believe changing supplier will magically make their line faster?
It's the same line, provided by BT at the end of the day, regardless of ISP. Always bemuses me, but then some ISPs do prey on the uninformed. Not Plusnet however.
Message 4 of 7
(656 Views)
04-09-2015 4:25 PM
Doesn't Sky being LLU have any effect?
Message 5 of 7
(656 Views)
04-09-2015 4:34 PM
Strange how it says speeds are the maximum when they are actually the minimum OR estimates they quote now.
Message 6 of 7
(656 Views)
04-09-2015 4:35 PM
Quote from: Alucidnation Doesn't Sky being LLU have any effect?
No because the sync speed is still negotiated with the BT FTTC cabinet. (On Sky LLU ADSL it is negotiated with the Sky equipment in the exchange which can make a difference)
Message 7 of 7
(656 Views)
