Visual Radius Graph request
Browni
Aspiring Hero
Fixes: 60
May I see my current graph please?
Many thanks in advance.
9 REPLIES 9
adamwalker
Fixes: 221
Re: Visual Radius Graph request
I won't bother with a graph as it doesn't really warrant it but you've had a connection for 69 days 10 hours. Smiley
 Adam Walker
Browni
Aspiring Hero
Fixes: 60
Thanks Adam, unfortunately that doesn't tie in with the the router's figure so I'm really none the wiser apart from knowing I do have a stable connection.
adamwalker
Fixes: 221
I'd not let it bother you unless you're seeing an issue.
Adam
 Adam Walker
Browni
Aspiring Hero
Fixes: 60
Obviously there isn't an issue but coming from an IT background I like figures than can be relied on.
Fixes: 1,601
What figures does your router report?
Browni
Aspiring Hero
Fixes: 60
This is the basic stats
Stats recorded 24 Apr 2018 15:57:52
DSLAM type / SW version:	BDCM:0xa48c (164.140) / v0xa48c
Modem/router firmware:  	AnnexA version - A2pvfbH043k.d26r
DSL mode:               	VDSL2 Profile 17a
Status:                 	Showtime
Uptime:                 	105 days 20 hours 47 min 11 sec
Resyncs:                	0 (since 24 Apr 2018 07:53:50)
				Downstream	Upstream
Line attenuation (dB):  	11.3		0.0
Signal attenuation (dB):	Not available on VDSL2
Connection speed (kbps):	79999		19999
SNR margin (dB):        	9.2		15.2
Power (dBm):            	12.8		-1.9
Interleave depth:       	16		1
INP:                    	48.00		0
G.INP:                  	Enabled		Not enabled
Vectoring status:       	5 (VECT_UNCONFIGURED)
Fixes: 1,601
Our tests are also showing your router in sync at 79.9mbps.
As for a longer up-time your router is showing it's possible that it didn't register a drop 71 days ago.
Browni
Aspiring Hero
Fixes: 60
Thanks @Gandalf,
Yep. 80Mbps give or take a bit or 2 Smiley
Although I do see that increasing in the not too distant future.
One or both uptimes are incorrect and as I have already proven your download figures to be incorrect I know which one I would bet on!
Browni
Aspiring Hero
Fixes: 60
Hmmm,
f8lure is showing uptime of 4281 hours at this moment in time.
just saying...
