Unstable Fibre Speed "Here we go again"
- Unstable Fibre Speed "Here we go again"
02-10-2019 4:19 PM
Re: Unstable Fibre Speed "Here we go again"
02-10-2019 4:26 PM
02-10-2019 4:33 PM
Upload Speed (Mbps) : 5.94
Ping Latency (ms): 47
unable to get beyond this point
04-10-2019 8:03 PM
The reply appears to be, " you can leave without penalty". WHAT ABOUT A FIX!!!!
05-10-2019 2:56 PM
Hi @smilers63, sorry for the delay in getting back to you.
Could you please rule your internal wiring out by plugging the connection into your test socket which is under the faceplate of your master socket and seeing if the speeds improve?
How to locate the test socket and set your connection into it can be found here
Let us know how it goes please.
05-10-2019 5:12 PM
my connection is in the master socket beneath the face plate
05-10-2019 5:15 PM
Upload Speed (Mbps) : 6.24
Ping Latency (ms): 24
05-10-2019 6:05 PM
The download IP profile appears to be stuck on 22399Mbps, can this be adjusted by PN.
05-10-2019 6:14 PM
06-10-2019 5:36 PM
Thanks for getting back to us @smilers63
I can see we're currently working on your fault ticket 194723874 and we plan to submit a DLM reset to our suppliers. I'd allow 2 to 3 working days for this to go through. Let us know how it goes.
