Unsatisfied Customer
- Re: Unsatisfied Customer
17-05-2015 8:04 PM
Have a look here to see if there is any information about your exchange. (Ignore the date at the top - when the page was created - look at the "reported" & Last updated dates).
17-05-2015 8:15 PM
FTTC Range B (Impacted) Download high 79.6 Download low 52.9 Upload high 20 upload low 12.2
adie:quote
17-05-2015 8:34 PM
Quote High Low High Low
FTTC Range A (Clean) 80 69.4 20 20 -- Available
FTTC Range B (Impacted) 80 60.7 20 12.2 -- Available
WBC ADSL 2+ Up to 11 -- 9 to 13 Available
WBC ADSL 2+ Annex M Up to 11 Up to 1 9 to 13 Available
ADSL Max Up to 8 -- 7 to 8 Available
WBC Fixed Rate 2 -- -- Available
17-05-2015 8:37 PM
PS.You'd better stop "Full Quoting" of immediately preceding posts, you'll have the mods on your tail. There is a Reply button and a Quick Reply box when replying directly to the last post or not needing to quote a specific part of a post.
And that mod must be just round the corner from you
17-05-2015 8:48 PM
17-05-2015 8:53 PM
17-05-2015 9:57 PM
19-10-2015 6:53 PM
P.S. here is my latest BT line checker I'm not on impacted thought I was
19-10-2015 8:37 PM
19-10-2015 8:40 PM
19-10-2015 8:51 PM
19-10-2015 9:43 PM
20-10-2015 10:27 AM
finding the make of the cab and install dates using the site is fine but finding the location of it can be hit and miss as it doesn't give an exact location just a general idea based on the postcode it has for the cab so you may still need to walk around to try and find it.
https://www.telecom-tariffs.co.uk/codelook.htm
20-10-2015 2:00 PM
20-10-2015 9:08 PM
