Unable to resolve DNS and 400+ms ping time
- Unable to resolve DNS and 400+ms ping time
- « Previous
- Next »
Re: Unable to resolve DNS and 400+ms ping time
29-09-2017 6:17 AM
I checked early this morning, the network should not be busy at this time....surprisingly slow
C:\Users\Sean>time /T
06:10
C:\Users\Sean>tracert ntp.plus.net
Tracing route to ntp.plus.net [212.159.13.50]
over a maximum of 30 hops:
1 1 ms <1 ms <1 ms 192.168.1.1
2 * * * Request timed out.
3 * * * Request timed out.
4 * * * Request timed out.
5 * * * Request timed out.
6 * * * Request timed out.
7 * * * Request timed out.
8 * * * Request timed out.
9 * * * Request timed out.
10 * * * Request timed out.
11 * * * Request timed out.
12 * * * Request timed out.
13 * * * Request timed out.
14 * * * Request timed out.
15 * * * Request timed out.
16 * * * Request timed out.
17 * * * Request timed out.
18 * * * Request timed out.
19 * * * Request timed out.
20 * * * Request timed out.
21 * * 25 ms cdns02.plus.net [212.159.13.50]
Trace complete.
C:\Users\Sean>nslookup bbc.co.uk
DNS request timed out.
timeout was 2 seconds.
Server: UnKnown
Address: 212.159.6.9
*** Request to UnKnown timed-out
C:\Users\Sean>
29-09-2017 6:44 AM
Hi Bob,
These tests have been run from a desk top computer over a wired connection to the JL router. Netflix and Amazon are on a smart TV behind my other router on a wired connection, we have found that they cannot load Amazon, and yes I understand that my router could still have an impact, but my desktop (Zak1) is having problems loading pages (these community pages, gmail, amazon, BBC), all the results I have pasted have been from Zak1.
Here is the ipconfig /all results......
06:18
C:\Users\Sean>ipconfig /all
Windows IP Configuration
Host Name . . . . . . . . . . . . : Zak1
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
Ethernet adapter Local Area Connection 2:
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Marvell Yukon 88E8001/8003/8010 PCI Gigabit Ethernet Controller
Physical Address. . . . . . . . . : 00-1B-FC-5D-1E-6F
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
Link-local IPv6 Address . . . . . : fe80::bccb:a8a5:bd78:4fe5%5(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.1.4(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Lease Obtained. . . . . . . . . . : 28 September 2017 17:32:15
Lease Expires . . . . . . . . . . : 30 September 2017 05:32:16
Default Gateway . . . . . . . . . : 192.168.1.1
DHCP Server . . . . . . . . . . . : 192.168.1.1
DHCPv6 IAID . . . . . . . . . . . : 301997052
DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-20-F7-01-67-00-1B-FC-5D-1E-6F
DNS Servers . . . . . . . . . . . : 212.159.6.9
212.159.6.10
NetBIOS over Tcpip. . . . . . . . : Enabled
Ethernet adapter Ethernet 2:
Media State . . . . . . . . . . . : Media disconnected
Description . . . . . . . . . . . : Generic Marvell Yukon 88E8055 PCI-E Gigabit Ethernet Controller
Physical Address. . . . . . . . . : 00-00-00-00-00-00
Tunnel adapter Teredo Tunneling Pseudo-Interface:
Description . . . . . . . . . . . : Teredo Tunneling Pseudo-Interface
Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0
DHCP Enabled. . . . . . . . . . . : No
IPv6 Address. . . . . . . . . . . : 2001:0:4137:9e76:242a:2858:3f57:fefb(Preferred)
Link-local IPv6 Address . . . . . : fe80::242a:2858:3f57:fefb%2(Preferred)
Default Gateway . . . . . . . . . : ::
DHCPv6 IAID . . . . . . . . . . . : 201326592
NetBIOS over Tcpip. . . . . . . . : Disabled
C:\Users\Sean>
Here is a another test without my netgear router attached(see attachment), wired connection to Zak1 and wifi disabled.....
06:39
1 <1 ms <1 ms <1 ms 192.168.1.1
18 * 1332 ms 25 ms cdns02.plus.net [212.159.13.50]
Trace complete.
Server: UnKnown
Non-authoritative answer:
Addresses: 2001:41c1:400c::bbc:2
2001:41c1:400c::bbc:1
2001:41c1:400c::bbc:3
2001:41c1:4008::bbc:2
2001:41c1:4008::bbc:1
2001:41c1:400c::bbc:4
2001:41c1:4008::bbc:3
2001:41c1:4008::bbc:4
212.58.244.23
212.58.246.79
212.58.244.22
212.58.246.78
C:\Users\Sean>
29-09-2017 1:00 PM
Hi there, I just wanted to make sure you've seen our latest response to ticket 157505178
29-09-2017 4:51 PM
16:48
Tracing route to ntp.plus.net [212.159.6.9]
4 25 ms 26 ms 26 ms be3-3104.psb-ir01.plus.net [195.166.143.136]
6 1672 ms 25 ms 26 ms cdns01.plus.net [212.159.6.9]
Trace complete.
C:\Users\Sean>NSlookup bbc.co.uk
Server: UnKnown
C:\Users\Sean>
29-09-2017 8:35 PM
Looking at the ipconfig output, I'd suggest you try disabling IPv6 on both the router interface and the PC. For the PC, go to the network connection properties and untick IPv6. Can easily be re-enabled if there's no change.
I can't put my finger on it, but something doesn't strike me as right, and I'm not 100% convinced it's this side of the Zyxel.
I'm almost tempted to send you an Openreach VDSL modem that you can try hooking up to the Netgear, but you can achieve similar by putting the Zyxel into bridge mode.
30-09-2017 1:34 PM
Moderator Note by Dick (Strat)
Duplicate post removed.
- « Previous
- Next »
