Switch from BT to Plusnet
- Switch from BT to Plusnet
28-07-2015 1:06 PM
I've just started the process of switching from BT Infinity to PlusNet Fibre.
I ordered a new PlusNet router when I signed up, but there was no mention of a engineer visiting to install an Openreach modem.
Do Plusnet assume I won't need a modem installed as I am switching from one fibre provider to another?
The problem is I'm currently using a BT Home Hub 5, so it doesn't use a separate Openreach modem.
Message 1 of 8
(1,882 Views)
7 REPLIES 7
Re: Switch from BT to Plusnet
28-07-2015 1:34 PM
You can use your Homehub 5 on Plusnet. See NorthEasterner’s sticky at the top of the Fibre page.
Message 2 of 8
(1,265 Views)
28-07-2015 2:06 PM
Message 3 of 8
(1,265 Views)
28-07-2015 3:03 PM
Thanks for the replies.
I quite like the idea of using the Home Hub 5. I didn't realise it could still be used when I placed my Plusnet order.
At least I'll have a spare router
Message 4 of 8
(1,265 Views)
29-07-2015 2:13 AM
(Edit to remove ambiguity: The plusnet router is) No use without a modem.
Message 5 of 8
(1,265 Views)
29-07-2015 1:49 PM
Message 6 of 8
(1,265 Views)
29-07-2015 2:08 PM
Although ambiguous, I think the "No use without a modem" comment was referring to the OP's comment about having a spare router when (if?) the PN one arrives, not the use of the HH5?
Message 7 of 8
(1,265 Views)
29-07-2015 4:50 PM
Correct :). The Plusnet router is only a spare one if it has a modem to feed it. Post edited.
Message 8 of 8
(1,265 Views)
