Stuck IP Profile
- Stuck IP Profile
- « Previous
- Next »
Re: Stuck IP Profile
24-07-2018 9:17 PM
BT Hub 6A
+084.....
SG4B1000B540
13-Jun-2018
1.0
1.64.0
0 Days, 13 Hours 46 Minutes 59 Seconds
18.87 Mbps / 49.00 Mbps
18867 / 61271
6.4 dB / 9.6 dB
19.6 dB
0/38
G_993_2_ANNEX_B
Fast Path
545 MB Uploaded / 30987 MB Downloaded
Active
BTH....
Smart (Channel 1)
BTH......
Smart (Channel 36)
WPA2 (Recommended)
Mode 1
On
AC....
9.2.0
24-07-2018 9:25 PM - edited 24-07-2018 9:27 PM
18867 / 61271
6.4 dB / 9.6 dB
19.6 dB
Hard to tell if your fibre is on G.INP Enabled, if it was, your line would get near around 56Meg on data rate (only if your cabinet are Huawei) as 49Meg isn't banded on the line. What does BT IP Profile say here: http://www.speedtest.btwholesale.com/PerformanceTesterWS/diagnostics.do and also check PN Current Line Speed here: https://portal.plus.net/my.html?action=data_transfer_speed
24-07-2018 9:31 PM
plusnet portal =
Estimated line speed:58Mb (This may vary between 40Mb and 58Mb) - Checked on 2018-06-19 15:40:14
Current line speed:47 Mb
24-07-2018 9:34 PM
@jasamd85 Current line speed:47 Mb seem about right but it need to check GEA Test by PN tomorrow if u ask them. Is your cabinet ECI or Huawei?
24-07-2018 9:36 PM
Previous to PLUSNET i have been with
BT
Vodafone
TalkTalk
EE
all with 65mb+!
This is bull from plusnet
24-07-2018 9:41 PM
What does your DSL Checker say here: https://www.dslchecker.bt.com/ and please don't post your tel phone number
24-07-2018 9:43 PM
Featured Products |
Downstream Line Rate(Mbps) |
Upstream Line Rate(Mbps) |
Downstream Handback Threshold(Mbps) |
WBC FTTC Availability Date |
WBC SOGEA Availability Date |
Left in Jumper |
High | Low | High | Low | ||||||
VDSL Range A (Clean) | 58.9 | 40 | 15 | 9.9 | 35 | Available | -- | -- | |
VDSL Range B (Impacted) | 48.4 | 30 | 12.8 | 6.9 | 25 | Available | -- | -- | |
Featured Products |
Downstream Range(Mbps) |
WBC FTTP Availability Date |
FTTP on Demand | 330 | 30 | -- | Available | -- | -- | |||
ADSL Products |
Availability Date |
Left in Jumper |
WBC ADSL 2+ | Up to 3 | -- | 2 to 6 | Available | -- | -- | |||
WBC ADSL 2+ Annex M | Up to 3 | Up to 0.5 | 2 to 6 | Available | -- | -- | |||
ADSL Max | Up to 2.5 | -- | 1.5 to 5 | Available | -- | -- | |||
WBC Fixed Rate | 1 | -- | -- | Available | -- | -- | |||
Other Offerings |
Availability Date |
VDSL Multicast | -- | -- | -- | Available | -- | -- | |||
ADSL Multicast | -- | -- | -- | Available | -- | -- | |||
Premise environment |
Status |
Bridge Tap | N | ||||||||
VRI | N | ||||||||
NTEFaceplate | N | ||||||||
Last Test Date | 17-07-2018 |
24-07-2018 9:44 PM
I know my speed is within the limits but i know for a fact my line is MUCH more capable of greater speeds as i have had fibre for over 6 years
24-07-2018 9:45 PM
. Best Effort Test: -provides background information.
Download Speed | |
134.6 Mbps |
0 Mbps | 47.38 Mbps Max Achievable Speed |
Download speed![]() For your connection, the acceptable range of speeds ![]() Additional Information: IP Profile for your line is - 47.38 Mbps |
Upload Speed | |
2.91 Mbps |
0 Mbps | 20 Mbps Max Achievable Speed |
Upload speed![]() Additional Information: Upstream Rate IP profile on your line is - 20 Mbps |
24-07-2018 9:49 PM
@jasamd85 I am afraid that it has changed due to more peoples connected in your cabinet due to crosstalk that reduced from High 65 to 58.9 now according to BT data:
Your Fibre should be getting around 56Meg if G.INP was Enabled or both G.INP Enabled and target SNR 3dB to get your line around 58Meg. But it cannot go faster than 58 at the moment.
24-07-2018 9:59 PM
How do we get this enabled then
24-07-2018 10:01 PM
It only done by DLM itself in time. Best to leave your Hub One ON at all times for the cabinet DLM to decided what next step as long your line remain stable. But PN cannot adjustment target SNR 3dB nor Plusnet cannot disabled interleaving or enabled G.INP. Only the DLM will do itself.
- « Previous
- Next »
