Speed fluctuations on gateways
- Re: Speed fluctuations on gateways
- « Previous
- 1
- 2
- Next »
27-01-2015 10:37 PM
28-01-2015 9:07 AM
Am I right to assume that you aren't swapping gateway each time the test varies from 33.8 to 36.6?
I had a similar effect 3 years ago - but only after swapping gateways; speeds would stay consistent once you had moved to a gateway. However, it was the change of gateway that was important, not the one you landed on. See this picture I annotated at the time, and you'll see pcl-ag04 appears twice, once with fast speeds, and once with slow speeds.
Those speed differences could also be seen on SamKnows tests, but only on the off-peak tests (at the time, fibre packages were throttled during peak hours)
Using FTTC since 2011. Currently on 80/20 Unlimited Fibre Extra.
28-01-2015 10:14 AM
Yes you are.
The following graph below is of my last 30 days, in which period I have switched from bng to ag07 back to bng. Just for a laff I shall now bounce to a none bng gateway then report back in a few days with an updated graph.
28-01-2015 10:25 AM
28-01-2015 10:57 AM
28-01-2015 11:34 AM
29-01-2015 2:33 PM
You are currently connected to gateway pcl-ag07.
This is located in City Lifeline House.
29-01-2015 5:39 PM
And annoying that I can't do any testing to figure things out either...
29-01-2015 6:10 PM
My normal shift is about 0.5mb by the way.
31-01-2015 4:27 PM
31-01-2015 8:02 PM
03-02-2015 9:24 PM
12-02-2015 1:13 PM
This is on ptw-bng02
- « Previous
- 1
- 2
- Next »
