Speed Fluctuations
- Speed Fluctuations
Speed Fluctuations
24-02-2015 10:27 PM
Hi, I'm a new customer to plusnet having switched from BT. I had infinity 1 with BT which have me a download speed of a solid 38mbps. Having switched to Plusnet I have found my speeds to be fluctuations massively especially at peak times I have found this problem with both wired and wireless connection. Often during peak times I am finding my download speed of less than 1mbps. The other day I managed to have a ping of 1017ms. I am unsure as to why this is as my BT connection was solid at all hours if the day. Does anyone have any suggestions?
Message 1 of 3
(719 Views)
2 REPLIES 2
Re: Speed Fluctuations
25-02-2015 9:03 AM
I have just run a BT wholesale speedtest and got the following results
Download 4.67mbps
Upload 10.16mbps
Latency 29.00mbps
Download 4.67mbps
Upload 10.16mbps
Latency 29.00mbps
Message 2 of 3
(446 Views)
25-02-2015 2:36 PM
Thank you for bringing this to our attention. We're not aware of any problems, so I'd suggest you raise a fault report here so we can investigate further.
Message 3 of 3
(446 Views)
