Some websites don't work
- Re: Some websites don't work
- « Previous
- 1
- 2
- Next »
05-11-2014 10:12 PM
Hi Neil and welcome to the forums.
If you log in to your router and hit the disconnect button and then reconnect you should hop to a different gateway (it may take a couple of tries).
Message 16 of 18
(168 Views)
06-11-2014 1:22 AM
Thanks avatastic, all seems ok now. Cheers.
Message 17 of 18
(168 Views)
06-11-2014 9:08 AM
Quote from: neilbradley Im also experiencing the same issue, I can barely load any websites other than plus.net!
Not really on that this is now a known issue and there is nothing on the service status page.
Is it possible to get me moved to another gateway also please so I can make a payment on hsbc.co.uk?
my plus.net id is neilbradleyuk
Hi Neil, welcome to the forums also.
I totally agree with you about the lack of Service Status - You may have noticed my earlier post #7 suggesting one, and my comment reply #12 that one had not appeared, so I don't know what happened there as Matthew was going to try and get it done. Ho hum.
Anyway all seems sorted now and as far as I can tell and AFAIK pcl-ag03 is now working normally.
Message 18 of 18
(168 Views)
- « Previous
- 1
- 2
- Next »
