Slowing fibre/dropouts
- Re: Slowing fibre/dropouts
31-08-2020 4:16 PM
Hi my connection dropped out a few days ago and since then has been unstable and has dropped connection a few times more.my speeds dropped 4mbs also and having checked the router instead of a 39.99 dload im down to 36 can anyone look into this as it makes a difference in a busy house.
Message 1 of 2
(356 Views)
1 REPLY 1
02-09-2020 4:34 PM
Hello @Higgi Together with our network partners at Openreach we will try to provide you with the best speeds possible. If you feel this is not the case, please raise your speed fault online at faults.plus.net
Message 2 of 2
(308 Views)
