Slow :(
rongtw
Fixes: 12
Slow :(
last few days i have noticed that web pages are gradually slowing down .
i have just done a BT speed test , cant do further diagnosis Sad   test  fails . am supposed to be 80/20 average is 72
36 REPLIES 36
rongtw
Fixes: 12
Re: Slow :(
still no better Sad   but not a fault untill i get below 50 :crazy2:  Ps nowt on service status or BT or Zen
St3
Aspiring Champion
Fixes: 5
Re: Slow :(
Tonight i have also noticed a drop in speeds from my normal speeds of 68 down 19 up. Maybe they working on the new network again Huh
rongtw
Fixes: 12
Re: Slow :(
rongtw
Fixes: 12
Re: Slow :(
rongtw
Fixes: 12
Re: Slow :(
St3
Aspiring Champion
Fixes: 5
Re: Slow :(
Ive just ran another test and it said the following
. Best Effort Test:
Download Speed : 67.82 Mbps
2. Upstream Test:
Upload Speed : 15.74 Mbps
Download has jumped back up but upload is slightly lower than i normally get, all i can think of is maybe they doing some work on somthing as we were both affected at the same time and we are miles apart.
rongtw
Fixes: 12
Re: Slow :(
@St3 mine still down Sad if it drops 2.3Mbps its a Fault :thumbsup:Capture.PNG
Fixes: 25
Re: Slow :(
Where are you getting the 50Mb fault threshold from? If that's the low A-range estimate, that applies to the line rate (sync speed) achieved by the modem, not a speedtest result.
rongtw
Fixes: 12
Re: Slow :(
@ejs   One of the staff told me :thumbsup:   i think its on the further diagnosis page If it runs ,, it the acceptable speed range
rongtw
Fixes: 12
Re: Slow :(
rongtw
Fixes: 12
Re: Slow :(
Still cant run the further diagnosis test ?  is it down again ? or just me :huh:
Fixes: 25
Re: Slow :(
Just you, you've been blocked from using it because you run too many speed tests. :tongue:
Terranova667
Re: Slow :(
Still down i haven't been able to run it for a couple of days now, I to have seen pings increase and my speed drop a bit, not sure what is going on, Can someone from plusnet staff post a GEA test so at least i can see what my profile is etc until BTW decide to fix the further diagnostic test.
Fixes: 726
Re: Slow :(
@rongtw
It appears to be a common issue across several circuits. We've raised this with our suppliers to investigate but there's no time frame for a fix I'm afraid. In regards to your speed issues...
Test Outcome Pass
Test Outcome Code GTC_FTTC_SERVICE_0003
Description No problem found, OAM test is not currently supported on this line.
Main Fault Location OK
Sync Status In Sync
Downstream Speed 80.0 Mbps
Upstream Speed 20.0 Mbps
Appointment Required N
Fault Report Advised N
NTE Power Status PowerOn
Voice Line Test Result Pass
Bridge Tap Not Detected
Estimated Line Length In Metres 86.0
Upstream Rate Assessment Very Good
Interference Pattern Regular Interference Observed Daily
Interference Duration Longest Occurrence ; 00:00 to 23:45
Interference Location Customer Premise
Interference Observed In Days 14
Technology VDSL
Profile Name 0.128M-80M Downstream, Interleaving Low - 0.128M-20M Upstream, Error Protection Off
...if you've done the usual i.e. testing using a wired connection and tried more than 1 device I'd recommend getting this reported to us as a fault at http://faults.plus.net
@Terranova667
Test Outcome Pass
Sync Status In Sync
Downstream Speed 44.4 Mbps
Upstream Speed 9.8 Mbps
Cross Talk Not Detected
Estimated Line Length In Metres 783.2
Upstream Rate Assessment Reasonable
Downstream Rate Assessment Reasonable
Customer Traffic Level Upstream and Downstream Traffic Detected
Technology VDSL
Profile Name 0.128M-80M Downstream, Error Protection Off - 0.128M-20M Upstream, Error Protection Off
