Slow Super Fibre
- Slow Super Fibre
Re: Slow Super Fibre
06-07-2017 12:06 PM
06-07-2017 12:21 PM
06-07-2017 3:18 PM
Unfortunately on FTTC the speeds drop quicker over distance than standard broadband.
When FTTC first goes live in a area some lines may have estimates which can't be achieved due to a mixture of reasons.
Over time you may find the estimates for your line drop to reflect what your currently getting.
06-07-2017 3:50 PM
@MatthewWheeler, have you raised the incorrect wording in the email with anyone?
06-07-2017 5:16 PM
18-07-2017 12:47 PM
18-07-2017 2:57 PM
Testing your connection shows you're in sync the smallest amount above the low end of the estimate for your line (Sync'd at 61.8Mbps with a low end estimate of 61.7Mbps)
Having said this, the test is also advising of a suspected phone fault. When testing the phone line, no fault is found
Could you try removing the faceplate of the master socket and connecting to the test socket to see if this gives any improvement please. This should rule out problems with internal wiring/the faceplate itself.
19-07-2017 10:46 AM
19-07-2017 11:43 AM
What you do is take the front off. Depending on the type of faceplate this is either clipped on or you remove two screws. You will then find another socket inside. Plug a different filter into this (you should have had one supplied with your router) and plug your router into the filter and try again preferable with nothing plugged in to the phone socket. This not only removes all your internal wiring (if any) from the circuit, it also allows the line to be tested with a different filter. This way if there is still a fault it is not being caused by you.
19-07-2017 11:56 AM
19-07-2017 2:28 PM
19-07-2017 3:30 PM
19-07-2017 5:07 PM
20-07-2017 8:44 AM
20-07-2017 9:23 AM
Hi @arpswetman
The estimated speeds are given during sign up. If you sign up online then they are quite clearly displayed before you get anywhere near the payment screens, and if you do it on the phone then they will be read out to you.
