Slow Broadband in the evenings
Fixes: 1,601
Re: Slow Broadband in the evenings
The resolution in that case was to contact our suppliers quality assurance team to investigate the issue.
They found congestion on the S-VLAN. In your case, they haven't I'm afraid.
br043871
That was after 4 engineer visits though wasn't it? It sounds like in the lonked case, BT fobbed Plusnet off so Plusnet fobbed the customer off. That strikes me as what is occuring just now.
What is it in my house that you think keeps breaking at peak times and rectifying itself at non peak times that an enginner could fix? I have already replaced the router.
Fixes: 1,601
Sorry to hear you feel that way.
If I remember correctly, we contacted our suppliers QA team after those engineer visits.
I'm more than happy to contact them again, which will have to be tomorrow as they're not open on bank holiday's.
Fixes: 1,601
Thanks for your patience.
I'm in the process of contacting QA now but there's a long queue. I'll post back when/if I've got through.
Fixes: 1,601
Thanks for waiting.
It looks like the S-VLAN is running hot after all. QA have dug into this deeper, and found that there are other reported speed faults to BT Wholesale regarding circuits on this VLAN.
They've advised me that whilst the throughput is below threshold, since Christmas Eve it's been spiking and has pretty much reached the threshold, so they've arranged to move your circuit to another VLAN which should complete tomorrow.
I'll update your ticket/send you an e-mail with more detail.
Fixes: 1,601
In light of this new information, I'll cancel the engineer visit we've got booked in.
br043871
OK thanks, let me know when this is done and I will check.
Fixes: 1,601
Looks like you're on a new a different VLAN.
How are your speeds?
br043871
The problem appears to be resolved tonight.
Fixes: 1,601
That's good to hear. Thumbs_Up Apologies for the length of time it's taken to reach this point. I believe this is being discussed in the superuser board to see if we can put steps in place to make improvements for diagnosing these types of issues.
Bluejay5
@Gandalf @br043871
I hope dont mind me gate crashing your thread could this be our problem our speeds has dropped to 8mbps
photo attached but its not gone off though
Martin
I love hobnobs you can nibble and then take a chunk out of it
Part of life living
br043871
It's possible that it is the same problem. It's a case of speaking to the right person at PlusNet who then in turn, has to speak with the right person at BT in order to get confirmation.
Bluejay5
Very true can I use this link to put on my one so I may get the response I don't want to set up another ticket if this can be sorted.
Martin
Moderator's note by Mike (Mav): Full quote of preceding post removed as per Forum rules.
Part of life living
veL
Im having the exact same problem. Speeds down to sub 10mb + High Latency. Screenshots attached in the thread.
Heres my thread ---> https://community.plus.net/t5/Fibre-Broadband/Slow-Speeds-in-the-Evenings-on-40-10/td-p/1503625
Bluejay5
This is mine hope @br043871 you did not mind
https://community.plus.net/t5/Fibre-Broadband/Plusnet-Fiber-Drop-38Mbps-to-12mbps/m-p/1503640#M70232
Part of life living
