Router setup details
- Re: Router setup details
19-11-2018 5:02 PM
I want to upgrade my router from the plus hub one. Does anyone have the setup specs, ie, MTU, etc?
Cheers
Gary
20-11-2018 9:20 AM
Hi @GaryWilliams,
This page will likely help with the basic settings for your connection. if you need any bespoke advice from the community I'd suggest advising the make and model of router you have purchased, or are intending to purchase, with any specific setting information you'd like and a brief description of your internal setup.
20-11-2018 11:08 AM
Hi Jolo,
OK, All the standard settings. Where in my account can I find my connection password?
Cheers
Gary
20-11-2018 11:41 AM
The connection password is the same as the password you login to the website with, so if you know that you already know the connection password
