Router is blue, but so am I, the Broadband's connected but the internet's died
- Re: Router is blue, but so am I, the Broadband's c...
08-03-2022 7:37 AM
Can anyone help me get this up and running? We live in a small village and I have no mobile data left (leeching off my husband's currently) and we both work from home.
Re: Router is blue, but so am I, the Broadband's connected but the internet's died
08-03-2022 7:41 AM
@DandF Welcome to the forums. Providing you have had confirmation from Plusnet that your account setup is complete, follow the instructions below. If you haven't had such confirmation, wait for it - THEN follow them.
Log in to the hub by putting 192.168.1.254 in the address field of your web browser.
On the Home page under My Services you will see the current Broadband Username. If it’s setup@plusdsl.net then it has not been configured by PlusNet authorisation systems.
First try a factory reset of the hub by pushing a paperclip or similar into the reset hole and hold the switch closed for at least 20 seconds, the LED should turn green and then release
Leave the Hub for around 10 minutes and check Home page for correct Broadband Username <your username>@plusdsl.net
If it still shows setup@plusdsl.net follow these steps.
Navigate from the Home page to >Advanced settings (you will be required to enter the Hub One admin password this found on bottom of the Hub or card with WiFi password).
Click on Continue to Advanced Settings then >Broadband >Internet
This page details your broadband Internet Connection Configuration.
Click on disconnect, if this does not work it may be necessary to remove the DSL cable.
Enter your correct username <your username>@plusdsl.net and password.
Plug in DSL cable (if removed) and click on Connect
Check your Hub One has logged on to the correct Broadband Username
08-03-2022 7:49 AM
08-03-2022 7:55 AM
Have you actually been advised that your connection is live on the Plusnet systems? If you have, then yes, you will need to contact PN.
There is a chance one of the Help Team will spot this topic and assist, but it may be quicker to ring in.
08-03-2022 7:58 AM
It's so frustrating as we were supposed to have it done on 18th Feb (Storm Eunice!) and it's cost a fortune in mobile data!
08-03-2022 8:32 AM
For reference, we were due to receive a connection on 18th Feb 2022, an Openreach van came out yesterday (7th March 2022), and now we may need to wait until 22nd March to be connected... No idea why we weren't informed our account was broken or how an account can even break.
This has cost a fortune in mobile data as I have no office to work out of. Very annoyed!
08-03-2022 8:37 AM
@DandF Sorry to hear that, but unfortunately it is happening with increased frequency - PN's accounts system is essentially 'not fit for purpose'.
09-03-2022 10:01 AM
Hiya @DandF,
I'm really sorry for the experience you have had and for the ongoing inconvenience this is causing.
I can assure you that our team will get this resolved and if you do need any further help in the meantime, please get back to me.
