Re-training after noise problems?
- Re: Re-training after noise problems?
24-03-2015 9:24 PM
When my line was first installed, I had a lot of issues with noise on the line and had to have engineers out a couple of times. It seems to have stopped now but my speed is down to 25Mbps down and about 3-4Mbps up. I was getting about 35-37 on a good day before.
Does my line need to go through retraining?
Thanks, Paul
Thanks, Paul
Message 1 of 4
(727 Views)
3 REPLIES 3
25-03-2015 1:28 PM
We'll need to go down the broadband faults route for this unfortunately. I can see that your line is synced at 32.4Mbps, significantly below the estimate for your line.
Can you run through https://faults.plus.net and we'll get this looked at.
Message 2 of 4
(380 Views)
01-04-2015 7:57 AM
I logged it through faults on the 25th and I've had no response back since then.
Message 3 of 4
(380 Views)
01-04-2015 11:21 AM
I'm sorry for the lack of response, I'll chase this with the faults team. I have tested the line though (some stats below) and notice that you've been on line for nearly a month. Can you please drop the PPP session and reboot the router and modem before letting us know if it still persists?
Sync Status In Sync
Downstream Speed 32.4 Mbps
Upstream Speed 4.3 Mbps
EDIT: As the sync has gone down though, faults will be investigating asap.
Sync Status In Sync
Message 4 of 4
(380 Views)
