Power line adaptors - checking power sockets?
- Power line adaptors - checking power sockets?
- « Previous
- 1
- 2
- Next »
Re: Power line adaptors - checking power sockets?
10-04-2015 4:09 PM
I think Oldjim in reply 2 was on the right path
I have a loft conversion where one socket will work with home plugs and another one won't. Reason is that a new circuit was put in for the conversion and the plug that works is on the old circuit connected to the downstairs sockets. You need to check the cbs in the distribution unit or units.
To do is to be - Neitzsche
To be is to do - Kant
do be do be do - Sinatra
Message 16 of 20
(238 Views)
10-04-2015 4:55 PM
I have successfully run a pair of TP-Link 200mbps home plugs on across two ring mains connected to different fuse boxes. The crucial thing is both fuse boxes were on the same meter (consumer unit).
If it was an issue with it being different ring mains etc I'd still expect it to work but perhaps nowhere near full speed.
Message 17 of 20
(238 Views)
10-04-2015 6:41 PM
I'm not sure but it could make a difference if each ring / spur was on a different RCD (not sure what effect these type of devices have an RF signals on the wires).
Call me 'w23'
Message 18 of 20
(238 Views)
10-04-2015 9:04 PM
If the wiring is fairly old (40+ years), it could even be Aluminium - in which case I'd just switch everything off at the mains.
Message 19 of 20
(238 Views)
10-04-2015 10:16 PM
artfulbodger,
What I have noticed on TP powerline adapters is they don't always pair if to far away.
This is the fix to try.
Put 2 power line adapters immediately next to each other (so 2 plugged into wall next to each other), then do the regular pairing procedure by pressing the pair buttons on each unit.
The pairing information is then save inside each powerline adapter, I can only assume there is a rechargeable battery in them.
Then unplug them and install in the sockets you originally intended.
Because of the pairing data that's just been saved there is a chance they will start working.
Message 20 of 20
(238 Views)
- « Previous
- 1
- 2
- Next »
