Power Off & DLM
- Power Off & DLM
Re: Power Off & DLM
08-06-2015 10:50 AM
If DLM on VDSL is more aggressive, its man-made that way and surely, like the simple rheostat fuel gauge, need a bit of damping?
All this speculation of how not to irritate it, or, having done so inadvertently, the living in hope that it will one day stir and respond favourably, has been discussed for months if not years. I think it's an issue, I suspect that others might too. A working solution cannot be difficult to implement surely, isn't it a simple software change? What harm does it do be underreacting?
Re: Power Off & DLM
08-06-2015 12:03 PM
Just thought I'd mention it!
York.
Re: Power Off & DLM
08-06-2015 12:07 PM
Quote from: chrcoluk Andy dont over rely on openreach for all your expert analysis, the same company gave you wrong information on ECI modem g.inp capability.
They've not given me any incorrect information.
Quote from: chrcoluk Here is what is a fact not theory, some users such as adslmax only did one single reboot of their modem, exceeding the 30 sec advisory you stated and were hit by DLM. Yet when the same guys waited 30mins the DLM didnt act. There is documentation somewhere about DLM counting disconnections for 15 min intervals, hence the 30 min advise.
Nope, adslmax/goldenfibre had DLM intervene for too many line errors (caused by the modem) - http://community.plus.net/forum/index.php/topic,132131.msg1153465.html#msg1153465
I believe there was another instance when he was trying new VDSL modem/routers and had many retrains which caused DLM to intervene.
DLM reviews 24 hour data, not 15 min data. The data itself is stored in 15 min bins.
Re: Power Off & DLM
08-06-2015 12:22 PM
Quote from: AndyH DLM reviews 24 hour data, not 15 min data. The data itself is stored in 15 min bins.
Just to clarify this. Are you saying that if I have enough disconnects within, let's say 30 minutes, for DLM to intervene, it will not do so immediately but will wait for the full 24 hour cycle to complete and then do so after?
Re: Power Off & DLM
08-06-2015 12:25 PM
Re: Power Off & DLM
08-06-2015 12:27 PM
Given that profiles are sent from the central management system (at whatever level) why on earth can a reset only be carried out by an engineer visit to the cab
Re: Power Off & DLM
08-06-2015 12:31 PM
Quote from: AndyH
incorrect again, we are talking about different events, and yes openreach did give you incorrect information, I will keep pointing this out until you run to the moderators again.
Re: Power Off & DLM
08-06-2015 12:33 PM
Quote from: alext05
what he said above is also incorrect. DLM can intervene at any time.
Re: Power Off & DLM
08-06-2015 12:51 PM
Quote from: Oldjim ........ why on earth can a reset only be carried out by an engineer visit to the cab
Apparently that's not the case Jim, see my reply #58
Re: Power Off & DLM
08-06-2015 12:57 PM
Quote from: Oldjim Given that profiles are sent from the central management system (at whatever level) why on earth can a reset only be carried out by an engineer visit to the cab
What AO said here was incorrect - resets are performed remotely. Fibre cabinets are rarely opened and few have access to them.
Quote from: chrcoluk incorrect again, we are talking about different events, and yes openreach did give you incorrect information, I will keep pointing this out until you run to the moderators again.
Which event are you referring to then? It's pointless if you cannot link to it.
Quote from: chrcoluk what he said above is also incorrect. DLM can intervene at any time.
Source?
Here is mine - https://www.openreach.co.uk/orpg/customerzone/products/industryforums/copperproductswlrllu/downloads...
Re: Power Off & DLM
08-06-2015 12:58 PM
Quote from: AndyH Yes. The fibre cabinets store the data and send it overnight to the Openreach management systems. The management systems review the data and if necessary, send a new line profile to be applied to your line (which gets applied between 01:00 and 06:00).
Thanks. I have now read more about it.
What about some users claiming that it can intervene at any time? Are there any exceptions when this can happen?
Re: Power Off & DLM
08-06-2015 1:05 PM
Re: Power Off & DLM
08-06-2015 1:06 PM
Quote from: AndyH
Yeh, well, completely ignore the link to his post I gave earlier, in a thread YOU referred to,
Quote from: goldenfibre ...if the customer power down less than 30 minutes of swapping modem over or turn on and off too many times then DLM will act next morning around 4am to 6am to put interleaving on and reduced the sync rate.It's happen to me last year when my sync rate was dropped to 72Meg from 79Meg and interleaving was put ON and disabled fast path by DLM. It's was removed three days later.
Re: Power Off & DLM
08-06-2015 1:11 PM
Quote from: Anotherone Yeh, well, completely ignore the link to his post I gave earlier, in a thread YOU referred to,
I suggest you read the thread in question rather than jumping to conclusions again.
adslmax was playing around with different modems that caused DLM to intervene. Based on what he posted, the MTBE/R exceeded the threshold.
The snr rate was also higher than normal that resulted in a lower sync speed.
Re: Power Off & DLM
08-06-2015 2:31 PM
Quote from: AndyH
As I'd already replied to Jim in the immediately preceding post and pointed out the reply where I admitted that based on your's and Jockwav's post that wasn't the case, what exactly was the point of your comment except it seems just another attempt to try to undermine every post I make here and therefore another personal attack, just like this -
Quote from: AndyH I suggest you read the thread in question rather than jumping to conclusions again.
You are obviously so intent on making a personal attack you did not read the thread to which I referred.
There is nothing in http://community.plus.net/forum/index.php/topic,139060.0.html from which my quoted GF post came. It was the last post on the thread.
