Plusnet Firewall EE Wifi Calling
- Re: Plusnet Firewall EE Wifi Calling
16-02-2018 12:03 PM - edited 16-02-2018 12:04 PM
Apologies if this has already been discussed but I couldn't get Wifi Calling to work with the Plusnet Broadband firewall settings on high, but when I changed them to low and restarted my router, Wifi Calling started to work. Is this something that Plusnet can change in their high settings to allow Wifi Calling? Or will I need to keep the firewall on low.
Thanks.
16-02-2018 12:37 PM - edited 16-02-2018 12:38 PM
If PN free firewall is giving you problems , you can always try a third party free on or even use the one Built into windows mine is set on low and i use windows firewall
https://www.techradar.com/news/the-best-free-firewall
16-02-2018 12:56 PM - edited 16-02-2018 12:57 PM
