PPP spinning after upgrade to fibre
- Re: PPP spinning after upgrade to fibre
20-10-2020 6:59 PM - edited 20-10-2020 6:59 PM
20-10-2020 7:13 PM
Have you contacted Plusnet?
If you cannot get through on the phone, you could follow the online troubleshooting guide at:
You will need to log in with your member centre credentials.
Regards
Richard
20-10-2020 7:19 PM
20-10-2020 7:51 PM
20-10-2020 9:27 PM
20-10-2020 9:51 PM
21-10-2020 7:45 AM
As you sound to be working from home, perhaps a backup method of accessing the internet is required.
Most mobile phone networks provide unlimited data packages but check the fair usage policys.
There is often a cap in the high hundreds of gigabytes.
There are introductory and cashback deals which significantly reduce the cost.
