No Dial Tone and Slow Fibre Broadband
- Re: No Dial Tone and Slow Fibre Broadband
17-03-2022 12:59 PM
Yesterday 16th March at around13.00 hrs, I used the text message service to report that I had no dial tone on my landline.
I had a response that no fault found and requesting my approval for further tests. That resulted in a second message saying a fault had been found and it was reported to engineers for a fix. I was then asked to complete a survey on myopinion of the new service
Since then no contact at all no progress report and no indication of an appointment for an engineer. This is not in accordance with the expectations reported on the help pages for phones.
In addition My broadband is running at around 4.1 mbps download and BT Wholesale speed test indicates that 4.23 mbps is the maximum speed my line will support. I have been getting around 28 to 30 mbps for the last 5 years at least. Is this purely a result of the reported phone fault?
17-03-2022 2:39 PM
No dial tone and slow internet is a symptom that one of the pair of BT cables feeding your master socket is disconnected somewhere. This should be automatically fixed when the phone fault is cleared.
18-03-2022 7:38 PM
Hey @agedgopher,
I'm really sorry for any inconvenience that this may have caused you. I've had a look at the account this evening and I can see that the phone fault appears to be resolved - is that the case from your end of things, or are you still having issues with the service?
18-03-2022 9:15 PM
Yes all sorted this afternoon. Openreach engineer arrived at the cabinet at about 13.10 and problem cleared at about 15.00 hrs.
Dial tone back and download speed now at around 35 mbps.
Thank you very much.
20-03-2022 8:26 PM
