Minimum speed guarantee
- Minimum speed guarantee
02-07-2020 2:45 AM
The maximum speed achievable on my line is 18.5mb.
I get no more than 17mb
Why give a guarantee that is impossible to achieve?
Re: Minimum speed guarantee
02-07-2020 7:33 AM
Moderators Note
This topic has been moved from ADSL Broadband to Fibre
02-07-2020 9:00 AM
Hi, if you cannot get the minimum speed of your contract, raise a fault at https://faults.plus.net. It will be investigated and if you cannot get the speed promised within 30 days then you should get a refund. At a minimum they must offer you the right to exit your contract without being penalised.
I know, because I had the same problem. I was pleased with my outcome ( product downgrade and refund - I was on unlimited fibre extra and couldn't hit the speeds of the lesser unlimited fibre product). Hope you get the solution you need.
https://www.plus.net/help/legal/ofcom-voluntary-speed-code-of-practice/
02-07-2020 9:19 AM
Be aware that the speed guarantee relates to the sync speed, not the speed as measured by a speed test. The measured speed will always be less than the sync speed. Check the sync speed in the router stats - if that is below the guaranteed minimum then raise a fault.
02-07-2020 9:58 AM
02-07-2020 10:50 AM
The guaranteed speeds should be the speeds that are indicated by the BT DSL checker - it is usually rather pessimistic so I'd be surprised if it was above the achievable speed (before I cancelled my line my guaranteed speed was 2Mbps, but I achieved >10Mbps).
Do you have the sign-up letter for your current contract that states that guaranteed minimum speed? If so I'd register a fault anyway (it may be a fault in Plusnet's systems but at the least you could probably negotiate some compensation!).
02-07-2020 11:42 AM
Hi @markroxxy123, thanks for getting in touch and I'm sorry to hear you're having speed issues as of recent. Together with our network partners at Openreach we are prioritising customers who don’t have a phone line or broadband connection, meaning there might be a delay in Speed Faults being fixed. In the meantime, please raise your speed fault online at faults.plus.net.
02-07-2020 12:07 PM
Regards
Mark
