Plusnet hub 1 flashing orange with red symbol
RohithR
This has been happening for some time now, our WiFi all of a sudden became orange with a red flashing symbol and we do not know how to fix it. We have tried to contact the Plusnet team however they are not responding to our calls. We have tried many methods to resolve our problem such as using different mastersockets as we have microfilters. We have tried factory resetting however this did not change anything. Somebody please help us resolve our issue.
5 REPLIES 5
Owain_2
Re: Plusnet hub 1 flashing orange with red symbol
Wifi flashing orange usually means the WPS button on the top right of the router has been pressed.
Or you may have a faulty router.
Is the wifi still working?
Fixes: 1,491
Moderators Note
This topic has been moved from ADSL Broadband to Fibre
RohithR
We did press the WPS button to see what it did and a new symbol popped up but then we factory resettled it and it disappeared however it went back to the orange display. We may have a faulty router however we cannot change it as no one will pick up the phone. We don't know what to do
tinytaco
Fixes: 29
Hi there @RhithR I can see that your connection has come back on since these posts, it looks like your router needed your username details to reconnect you. Please get back in touch if you have any further issues Smiley
 Noor
RohithR
Hello my WiFi was fixed however this morning I have had the same issue and it is flashing orange. Then it shows the red symbol but it is not flashing.
