Line speed drop - any advice?
FIXED- Subscribe to RSS Feed
- Line speed drop - any advice?
27-03-2018 10:12 PM
My most recent sync is
8:13:40, 27 Mar. ( 134.650000) PPPoE is up - Down Rate=42301Kbps, Up Rate=18143Kbps;
SNR Margin Down=5.9dB, Up=5.7dB
This is now well below the BT estimate
Downstream Line Rate(Mbps) Upstream Line Rate(Mbps) Downstream Handback Threshold(Mbps)
High Low High Low
VDSL Range A (Clean) 74.8 52.2 20 14.8 44
It has been falling in stages, but this is a new low
02:03:24, 08 Aug. ( 131.150000) PPPoE is up -? Down Rate=51300Kbps, Up Rate=19680Kbps;
SNR Margin Down=6.1dB, Up=6.0dB
00:11:26, 21 Dec. (4584969.870000) PPPoE is up -? Down Rate=47372Kbps, Up Rate=17375Kbps;
SNR Margin Down=5.9dB, Up=5.8dB
19:36:36, 29 Jan. ( 129.020000) PPPoE is up -? Down Rate=46249Kbps, Up Rate=17777Kbps;
SNR Margin Down=5.9dB, Up=5.9dB
Fixed! Go to the fix.
Re: Line speed drop - any advice?
28-03-2018 10:12 AM
28-03-2018 7:37 PM
Many thanks for replying and line testing. I waited 24 hrs and re-synched and it's back to how it's been for the last 3 months - still below the BT estimate but I don't think an engineer visit will really help yet - unless they lay a new cable that is ! I've already/ got a recent face-plate etc
19:28:58, 28 Mar. ( 129.550000) PPPoE is up - Down Rate=46092Kbps, Up Rate=17278Kbps;
01-04-2018 3:34 PM
Glad to hear your speeds have improved.
If your speeds drop anymore I'd recommend raising a fault here so we can arrange an engineer just to make sure there's no problems on the Openreach network.
02-04-2018 12:49 PM
