Line speed capped?
FIXEDTopic Options
- Re: Line speed capped?
04-03-2020 11:53 PM
hi can you please do a full GEA test and report the results here. Also if the line has been banded, please do a DLM reset as well. Thank you.
Fixed! Go to the fix.
Message 1 of 4
(752 Views)
3 REPLIES 3
10-03-2020 1:20 PM
Hiya @jclau, It looks like you are banded at 35mb and so I've sent off the request for a reset for you. I'll attach the GEA below for you.
Message 2 of 4
(667 Views)
10-03-2020 1:21 PM
Test Outcome | Pass |
Test Outcome Code | GTC_FTTC_SERVICE_0000 |
Description | GEA service test completed and no fault found . |
Main Fault Location | OK |
Sync Status | In Sync |
Downstream Speed | 35.0 Mbps |
Upstream Speed | 7.2 Mbps |
Appointment Required | N |
Fault Report Advised | N |
NTE Power Status | PowerOn |
Voice Line Test Result | Pass |
Bridge Tap | Not Detected |
Radio Frequency Ingress | Not Detected |
Repetitive Electrical Impulse Noise | Not Detected |
Cross Talk | Not Detected |
Estimated Line Length In Metres | 606.5 |
Upstream Rate Assessment | Low |
Downstream Rate Assessment | Low |
Interference Pattern | Not Detected |
Service Impact | No Impact Observed |
Home Wiring Problem | Not Detected |
Downstream Policing Discard Rate | 0.0 |
Customer Traffic Level | Upstream and Downstream traffic detected |
Technology | VDSL |
DP Type | External |
Profile Name | 0.128M-35M Downstream, Error Protection Off - 0.128M-7.2M Upstream, Error Protection Off |
Time Stamp | 2020-02-26T13:00:00 |
Parameters | MIN | MAX | AVG |
Down Stream Line Rate | 34.9 Mbps | 34.9 Mbps | 34.9 Mbps |
Up Stream Line Rate | 7.1 Mbps | 7.1 Mbps | 7.1 Mbps |
Up Time | 900.0 Sec | 900.0 Sec | 900.0 Sec |
Retrains | 0.0 | 0.0 | 0.0 |
Current and Last 15 Minute Bin Performance | ||
Parameters | Last Traffic Count(Upto 15 mins) | Current Traffic Count(Upto 15 mins) |
Start Time Stamp | 2020-03-10T12:32:13.340+00:00 | 2020-03-10T12:47:13.340+00:00 |
Ingress Code Violation | 0 | 0 |
Egress Code Violation | 0 | 0 |
Errored Seconds | 0 | 0 |
Severely Errored Seconds | 0 | 0 |
Unavailable Seconds | 0 | 0 |
Message 3 of 4
(666 Views)
12-03-2020 4:53 PM
The line is now faster. Thank you very much.
Message 4 of 4
(617 Views)
