Huge ping spikes of 2000ms~ every 4-5 seconds.
- Huge ping spikes of 2000ms~ every 4-5 seconds.
10-09-2017 10:29 AM - edited 10-09-2017 10:36 AM
Hey!
For the last 3 weeks I've been faced with the problem of huge ping spikes of 1000ms-2000ms every 4-5 seconds. Restarting the plusnet router stops this problem for a few hours, but not permanantly. How would I go about resolving this? Thanks!
Example of me pinging www.google.com:
Reply from 216.58.208.164: bytes=32 time=1661ms TTL=52 Reply from 216.58.208.164: bytes=32 time=34ms TTL=52 Reply from 216.58.208.164: bytes=32 time=22ms TTL=52 Reply from 216.58.208.164: bytes=32 time=38ms TTL=52 Reply from 216.58.208.164: bytes=32 time=20ms TTL=52 Reply from 216.58.208.164: bytes=32 time=25ms TTL=52 Request timed out. Reply from 216.58.208.164: bytes=32 time=1380ms TTL=52 Reply from 216.58.208.164: bytes=32 time=18ms TTL=52 Reply from 216.58.208.164: bytes=32 time=19ms TTL=52 Reply from 216.58.208.164: bytes=32 time=26ms TTL=52 Reply from 216.58.208.164: bytes=32 time=23ms TTL=52 Reply from 216.58.208.164: bytes=32 time=20ms TTL=52 Reply from 216.58.208.164: bytes=32 time=987ms TTL=52 Reply from 216.58.208.164: bytes=32 time=18ms TTL=52 Reply from 216.58.208.164: bytes=32 time=18ms TTL=52 Reply from 216.58.208.164: bytes=32 time=18ms TTL=52 Reply from 216.58.208.164: bytes=32 time=14ms TTL=52 Reply from 216.58.208.164: bytes=32 time=1603ms TTL=52 Reply from 216.58.208.164: bytes=32 time=14ms TTL=52 Reply from 216.58.208.164: bytes=32 time=23ms TTL=52 Reply from 216.58.208.164: bytes=32 time=29ms TTL=52 Reply from 216.58.208.164: bytes=32 time=28ms TTL=52 Reply from 216.58.208.164: bytes=32 time=1198ms TTL=52 Reply from 216.58.208.164: bytes=32 time=21ms TTL=52 Reply from 216.58.208.164: bytes=32 time=20ms TTL=52 Reply from 216.58.208.164: bytes=32 time=55ms TTL=52 Reply from 216.58.208.164: bytes=32 time=58ms TTL=52 Request timed out. Reply from 216.58.208.164: bytes=32 time=46ms TTL=52 Reply from 216.58.208.164: bytes=32 time=1188ms TTL=52 Reply from 216.58.208.164: bytes=32 time=16ms TTL=52 Reply from 216.58.208.164: bytes=32 time=31ms TTL=52 Reply from 216.58.208.164: bytes=32 time=19ms TTL=52 Reply from 216.58.208.164: bytes=32 time=1714ms TTL=52 Reply from 216.58.208.164: bytes=32 time=16ms TTL=52 Reply from 216.58.208.164: bytes=32 time=21ms TTL=52 Reply from 216.58.208.164: bytes=32 time=39ms TTL=52 Reply from 216.58.208.164: bytes=32 time=1790ms TTL=52 Reply from 216.58.208.164: bytes=32 time=21ms TTL=52 Reply from 216.58.208.164: bytes=32 time=16ms TTL=52 Reply from 216.58.208.164: bytes=32 time=18ms TTL=52 Reply from 216.58.208.164: bytes=32 time=1661ms TTL=52 Reply from 216.58.208.164: bytes=32 time=19ms TTL=52 Reply from 216.58.208.164: bytes=32 time=45ms TTL=52 Reply from 216.58.208.164: bytes=32 time=21ms TTL=52 Reply from 216.58.208.164: bytes=32 time=37ms TTL=52 Reply from 216.58.208.164: bytes=32 time=807ms TTL=52 Reply from 216.58.208.164: bytes=32 time=23ms TTL=52 Reply from 216.58.208.164: bytes=32 time=15ms TTL=52 Reply from 216.58.208.164: bytes=32 time=34ms TTL=52 Reply from 216.58.208.164: bytes=32 time=1461ms TTL=52 Reply from 216.58.208.164: bytes=32 time=19ms TTL=52 Reply from 216.58.208.164: bytes=32 time=26ms TTL=52 Reply from 216.58.208.164: bytes=32 time=26ms TTL=52 Reply from 216.58.208.164: bytes=32 time=29ms TTL=52 Request timed out. Reply from 216.58.208.164: bytes=32 time=1348ms TTL=52 Reply from 216.58.208.164: bytes=32 time=26ms TTL=52 Reply from 216.58.208.164: bytes=32 time=15ms TTL=52 Reply from 216.58.208.164: bytes=32 time=24ms TTL=52 Reply from 216.58.208.164: bytes=32 time=15ms TTL=52 Request timed out. Reply from 216.58.208.164: bytes=32 time=974ms TTL=52 Reply from 216.58.208.164: bytes=32 time=23ms TTL=52 Reply from 216.58.208.164: bytes=32 time=17ms TTL=52 Reply from 216.58.208.164: bytes=32 time=14ms TTL=52 Reply from 216.58.208.164: bytes=32 time=25ms TTL=52 Request timed out. Request timed out. Request timed out. Reply from 216.58.208.164: bytes=32 time=46ms TTL=52 Reply from 216.58.208.164: bytes=32 time=16ms TTL=52 Reply from 216.58.208.164: bytes=32 time=19ms TTL=52 Reply from 216.58.208.164: bytes=32 time=1168ms TTL=52 Reply from 216.58.208.164: bytes=32 time=21ms TTL=52 Reply from 216.58.208.164: bytes=32 time=21ms TTL=52 Reply from 216.58.208.164: bytes=32 time=14ms TTL=52 Reply from 216.58.208.164: bytes=32 time=21ms TTL=52 Reply from 216.58.208.164: bytes=32 time=916ms TTL=52 Reply from 216.58.208.164: bytes=32 time=43ms TTL=52
EDIT: I've just deleted all ports I opened, and the ping has returned back to normal. Hopefully this was the issue and it won't happen again.
Message 1 of 2
(626 Views)
1 REPLY 1
Re: Huge ping spikes of 2000ms~ every 4-5 seconds.
11-09-2017 4:12 PM
Message 2 of 2
(581 Views)
