Frequent line drop-outs
robg1969
I get probably 5-20 line dropouts per day.  It can happen at any time and under any circumstances.
The Plusnet router stopped working so it's been replaced with an Asus VSDL router which has a lot more control over everything.  The settings are all  set up to run 'stable' (rather than for maximum speed), but still the dropouts persist.
I think there may be a fault with the line.  I had PN fibre at our old address any only get very occasional dropouts.  At this address it's an order of magnitude worse!
I don't have a telephone to check the 'sound' of the line (line is used for broadband only).
What can be done?
1 REPLY 1
MatthewWheeler
Fixes: 480
Re: Frequent line drop-outs
From what we can see you haven't had any drops over the past few days as shown below
The speeds however are lower then expected so I'd recommend raising a fault here
 Matthew Wheeler
