Hub One dropping connection
- Hub One dropping connection
22-10-2016 1:32 PM
After years of stable ADSL I moved to FTTC with it going live on the 19th. The supplied Hub One switched over from ADSL to fibre (40 / 2) without a problem and all seemed well until I noticed this morning that the connection with my Synology DS215J had dropped. Checking the Hub's event log showed that there had been a succession of PPPoE drops since the 20th (see below). Is this likely to indicate a faulty router or is there a line fault?
00:41:36, 20 Oct. (37377.610000) PPPoE is down after 617 minutes uptime [Disconnected]
00:45:11, 20 Oct. (37592.060000) PPPoE is up - Down Rate=27363Kbps, Up Rate=2000Kbps; SNR Margin Down=6.4dB, Up=13.7dB
04:55:48, 21 Oct. (139029.240000) PPPoE is down after 1690 minutes uptime [Waiting for Underlying Connection (WAN Ethernet 7 - Down)]
04:57:11, 21 Oct. (139111.710000) PPPoE is up - Down Rate=24798Kbps, Up Rate=2001Kbps; SNR Margin Down=7.3dB, Up=14.4dB
05:03:00, 21 Oct. (139460.470000) PPPoE is down after 5 minutes uptime [Waiting for Underlying Connection (WAN Ethernet 7 - Down)]
05:04:21, 21 Oct. (139541.510000) PPPoE is up - Down Rate=24982Kbps, Up Rate=2001Kbps; SNR Margin Down=7.6dB, Up=14.3dB
06:34:43, 21 Oct. (144963.720000) PPPoE is down after 90 minutes uptime [Waiting for Underlying Connection (WAN Ethernet 7 - Down)]
06:36:05, 21 Oct. (145045.820000) PPPoE is up - Down Rate=24830Kbps, Up Rate=2001Kbps; SNR Margin Down=7.7dB, Up=14.3dB
18:05:24, 21 Oct. (186404.640000) PPPoE is down after 689 minutes uptime [Waiting for Underlying Connection (WAN Ethernet 7 - Down)]
18:06:47, 21 Oct. (186487.810000) PPPoE is up - Down Rate=23876Kbps, Up Rate=2001Kbps; SNR Margin Down=7.3dB, Up=14.4dB
04:36:13, 22 Oct. (224253.870000) PPPoE is down after 629 minutes uptime [Waiting for Underlying Connection (WAN Ethernet 7 - Down)]
04:37:36, 22 Oct. (224336.340000) PPPoE is up - Down Rate=23177Kbps, Up Rate=2001Kbps; SNR Margin Down=7.7dB, Up=14.3dB
10:30:13, 22 Oct. (245493.950000) PPPoE is down after 352 minutes uptime [Waiting for Underlying Connection (WAN Ethernet 7 - Down)]
10:31:36, 22 Oct. (245576.490000) PPPoE is up - Down Rate=23419Kbps, Up Rate=2001Kbps; SNR Margin Down=7.6dB, Up=14.3dB
Re: Hub One dropping connection
24-10-2016 10:29 AM
We're seeing a few disconnections, which seem to tally up with the timestamps in your logs:
24-10-2016 12:17 PM
No further drops Chris. The drop last Monday was, I suspect, when I swapped out the old TP-Link for the Hub 1. Before that connections seemed to be rock solid, certainly I never noticed any issues and the router seemed to be up for ever. The Hub 1 seems to be stable at the moment having stayed up for over a day. I will monitor it over the next few days to see if it has indeed settled down.
24-10-2016 3:08 PM
Thanks, let us know how it goes and we can check for disconnections if they come back again.
26-10-2016 2:19 PM
Problem is still here. Hub 1 lost connection just now:
14:09:32, 26 Oct.
(604252.280000) CWMP: Server URL: https://dbtpnhdm.bt.mo; Connecting as user: ACS username
14:09:32, 26 Oct.
(604252.270000) CWMP: Session start now. Event code(s): '4 VALUE CHANGE'
14:09:32, 26 Oct.
(604252.020000) CWMP: Initializing transaction for event code 4 VALUE CHANGE
14:09:29, 26 Oct.
(604249.180000) PTM over DSL is down after 278 minutes uptime
14:09:29, 26 Oct.
(604249.180000) PPPoE is down after 276 minutes uptime [Waiting for Underlying Connection (WAN Ethernet 7 - Down)]
14:09:26, 26 Oct.
(604246.180000) PPP LCP Send Termination Request [User request]
and then came back with:
14:10:51, 26 Oct.
(604331.500000) PPPoE is up - Down Rate=17923Kbps, Up Rate=1999Kbps; SNR Margin Down=6.2dB, Up=15.0dB
I think that is the second drop today and there was one on Tuesday morning.
I ran a quiet line test this morning and all appeared well, so line noise shouldn't be causing the problem.
