Groundhog Day.
newagetraveller
Re: Groundhog Day.
Thanks for the ticket update, but  "Connection is continuing to drop out an Impairment in the Copper Joint has been detected when testing the line."
The quoted has been the "diagnosis" each time which results in OR attending, finding no faults (i.e. speeds as they should be), changing the faceplate and resetting the line. It will then be perfect for a time until back to the poor speeds. What is "the" copper joint?
Once more I ask, what will result if the above paragaph happens yet again? Do OR keep coming out to do the same each time?
Yesterday morning the speeds were about 1.7 down and 0.1 up. Soft reset of the Hub One made no difference. Powered off the router, restarted and speeds returned to those illustrated in the BT results.
Fixes: 1,600
Re: Groundhog Day.
However, from a previous post, " if OR attend again, find nothing wrong and probably carry out a line reset, what's the next step when the same thing inevitably occurs again, i.e. Groundhog Day!?"
We could potentially raise an escalation with BT Wholesale.
newagetraveller
Re: Groundhog Day.
And what is "the copper joint"?
Fixes: 1,600
Re: Groundhog Day.
That could be anything along the line.
Our tests have just detected a possible issue on the line.
newagetraveller
Re: Groundhog Day.
OR turned up this morning about 8.30 out of the blue. He did spend some time and confirmed the reduced speed but found no faults, again! Reset the line, again!
Hub One left in test socket to see what happens. He mentioned escalating to a Boost? Engineer.
Of course there were hints that it could be a faulty Hub One or some sort of interference affecting the router. On a wired connection and why only since upgrading to 80/20? Everything was perfectly stable on 40/10.
Fixes: 1,600
Re: Groundhog Day.
I'm sorry to hear the engineer couldn't find a problem.
Unfortunately we can't arrange boost engineers. I think it would be a good idea to rule out the router next, so I'm sending you a replacement which you should receive within the next few days.
If you're still experiencing connection issues following that please let us know and we'll raise an escalation with BT Wholesale, requesting a more experienced engineer is assigned.
newagetraveller
Re: Groundhog Day.
I suppose the router cannot be fully eliminated. However, the first speed reduction occured using a TPLink AC1900, the next with a BT Smart hub 6 then the Hub One.
The OR "engineer" advised to keep the existing Hub One connected to the test socket to wait and see if and when it happens again. Apparently this would give them a better idea.
Do I use the replacement Hub One or leave everything as it is as advised? I suspect it will be a waste of postage and a new Hub One.
Would being supplied via two linked cabinets have any bearing? ADSL was connected to CAB1 about a mile away, then VDSL was transferred to CAB9 about 200 yds. away.
Also would "the copper joint" fault indicate a router problem? Apparently that indicates a high resistance somewhere which is often caused by a poor/loose connection which could be anywhere!
Fixes: 1,600
Re: Groundhog Day.
I'd recommend using the new Hub One in case there is problem with your existing one.
That shouldn't make a difference.
The fault location in our test results can be wrong occasionally as it's difficult to remotely determine 100% where the location of the fault lies until an engineer visits. Testing your line yesterday was showing:
GEA service test completed and no fault found .
As opposed to Impairment in copper joint detected most likely in local network. previously.
Keep us posted.
newagetraveller
Re: Groundhog Day.
Thanks Anoush. Hub One received yesterday.
There will be a disconnection showing at circa 8am when I swapped over. Using the new microfilter and cables too.
I will, of course, advise of any further deterioration. Smiley
Fixes: 1,600
Re: Groundhog Day.
No problems at all.
Fingers crossed that improves your connection.
newagetraveller
Re: Groundhog Day.
Well that didn't take long. Lost connection at 10 am. Now as below. Do you want the "new" Hub One back?Roll_eyes I knew it wasn't the router/modem.
Fixes: 1,600
Re: Groundhog Day.
Sorry to hear you're still having issues.
Our testing isn't showing any issues and your connection seems to be a lot more stable in the past week:
Unfortunately due to the relatively low number of the drops, as it stands it's unlikely to be accepted as a fault.
Can you let us know if the drops increase in frequency?
RealAleMadrid
Aspiring Hero
Fixes: 59
Re: Groundhog Day.
Surely it must be a reportable speed fault if the OP is only getting around 30Mbps with a 76Mbps IP profile
I wouldn't agree that one or two line drops a day is considered to be stable either. I suspect there is still a line fault that Openreach can't locate or fix.Angry
newagetraveller
Re: Groundhog Day.
Here is this morning's result.
I have responded to the open ticket, 17099967, Anoush.
"I suspect there is still a line fault that Openreach can't locate or fix.Angry" Or equipment, which might take up too much time to locate and/or money to fix.
The Friday 8am event was connecting the replacement Hub One, which I advised in my post on that day. The 10am Saturday was the disconnection, not of my doing, after which the speeds deteriorated again.
newagetraveller
Re: Groundhog Day.
To quote the written words of the late Douglas Adams. "So long and thanks for all the fish."
Long time customer off to pastures new.
