GEA Test
goldenfibre
Seasoned Pro
Fixes: 12
GEA Test
Hi PN
Could I have my line GEA Test please
5 REPLIES 5
MatthewWheeler
Fixes: 480
Re: GEA Test
Thanks for getting in touch @goldenfibre.
I've provided this for you below
Test Outcome Pass
Main Fault Location OK
Sync Status In Sync
Downstream Speed 79.9 Mbps
Upstream Speed 20.0 Mbps
Appointment Required N
Fault Report Advised N
NTE Power Status PowerOn
Voice Line Test Result Pass
Bridge Tap Not Detected
Cross Talk Not Detected
Estimated Line Length In Metres 253.1
Upstream Rate Assessment Very Good
Customer Traffic Level Upstream and Downstream Traffic Detected
Technology VDSL
Current 15Min Bin Retrains 0
Last 15Min Bin Retrains 0
DP Type External
Profile Name 0.128M-80M Downstream, Retransmission Low - 0.128M-20M Upstream, Error Protection Off
Time Stamp 2020-01-16T13:00:00
Parameters MIN MAX AVG
Down Stream Line Rate 79.9 Mbps 79.9 Mbps 79.9 Mbps
Up Stream Line Rate 19.9 Mbps 19.9 Mbps 19.9 Mbps
Up Time 0.0 Sec 900.0 Sec 882.2 Sec
Retrains 0.0 3.0 0.0
Current and Last 15 Minute Bin Performance
Parameters Last Traffic Count(Upto 15 mins) Current Traffic Count(Upto 15 mins)
Start Time Stamp 2020-01-29T12:36:13Z 2020-01-29T12:51:13Z
Ingress Code Violation 0 0
Egress Code Violation 0 0
Errored Seconds 0 0
Severely Errored Seconds 0 0
Unavailable Seconds 0 0
 Matthew Wheeler
Shep41
Seasoned Pro
Fixes: 6
Re: GEA Test
Matthew did you forget to attach the GEA test results ?
Derrrrrrr it's showing now .😆😆😆
goldenfibre
Seasoned Pro
Fixes: 12
Re: GEA Test
@MatthewWheeler
Thanks for the GEA Test but what is this Traffic Detected by customer traffic level?
RealAleMadrid
Aspiring Hero
Fixes: 59
Re: GEA Test
@goldenfibre  It means you are using your broadband connection. Traffic, that is data has been flowing downstream and upstream.😁
Fixes: 1,602
Re: GEA Test
What @RealAleMadrid said Cheesy
